I just went to do something on my HTPC and it said I had no space left. Looked about and found 50GB in the 'NPVR Timeshift' folder!
Anyone know why this is happening?
It shouldn't do. Have you got the latest patches installed from the NextPVR forums?
I put the latest patches on about a week ago to get NPVR to work in XBMC.
It's put another 13GB in there since my last post.
What type of tuner are you using?
You'll need to post the NextPVR logs over at the NextPVR forums and I'll take a closer look for you.
OK will do.
Which logs? There is a lot in the log folder.
