2013-01-19, 18:46
As per title, no pop up windows for subtitle and i cant download and get it to work anymore, here is my debug log http://pastebin.com/ySUjapLx
(2013-01-20, 01:13)misa Wrote: [ -> ]disable the allinone script
What do you mean by that?
(2013-01-20, 01:20)ronie Wrote: [ -> ]ahhhhhh.... finally its workin again... thx ronnie . for the developer.... any chance to get this fix?(2013-01-20, 01:13)misa Wrote: [ -> ]disable the allinone script
eh, well.. if you have installed the allinone addon,
temporary disable it to see if that fixes the issue.
addons can be disabled in the addon manager:
settings > addons > enabled addons > program addons > all in one
select the addon and click 'disable'.
it's the same issue as you're having with 1ch btw.
(2013-01-20, 04:00)mayatsan Wrote: [ -> ](2013-01-20, 01:20)ronie Wrote: [ -> ]ahhhhhh.... finally its workin again... thx ronnie . for the developer.... any chance to get this fix?(2013-01-20, 01:13)misa Wrote: [ -> ]disable the allinone script
