Full Version: XBMC crashes on open
Hi all,
I've just tried to install XBMCbuntu, twice.
I'm using my old laptop - a compaq presario v2000 with an AMD sempron and ati radeon xpress 200M.
The problem I'm having is that any time i try to open XBMC. Of course, this makes me very sad :`-(
I have no idea what's going on. I suspected graphics driver, so I tried to follow the instructions here : http://forum.xbmc.org/showthread.php?tid=152670
however, even with fglrx-legacy drivers, xbmc still doesn't work.
here's my crash log, let me know if there's any other info that would help.
https://docs.google.com/file/d/0ByTYhsbH...hNRE0/edit
https://docs.google.com/file/d/0ByTYhsbH...ltUUE/edit
Thanks,
JR
You can use XBMC10.1 Dharma, but there's issues getting AddOns and Scrapers to work.
Bodhi Linux / XBMC works well with Compaq Presario.
I followed this guide:
https://www.youtube.com/watch?v=QA_xUOnVfJE
I now have Presario V2000 running XBMC 12
For Old ATI Graphics in Bodhi, this worked for me:
sudo apt-get install build-essential linux-headers-$(uname -r) pkg-config ~(Optional for building other Video Drivers)~
sudo apt-get remove --purge fglrx fglrx_* fglrx-amdcccle* fglrx-dev* xorg-driver-fglrx
sudo apt-get remove --purge xserver-xorg-video-ati xserver-xorg-video-radeon
sudo apt-get install xserver-xorg-video-ati
sudo apt-get install --reinstall libgl1-mesa-glx libgl1-mesa-dri xserver-xorg-core
sudo reboot
Install XBMC:
sudo apt-get dist-upgrade ~(This breaks broadcom wifi)~
sudo apt-get install pulseaudio pavucontrol ubuntu-restricted-extras xbmc
Set XBMC to auto-login:
sudo su
sed -i 's/last/#last/'g /etc/lxdm/default.conf
echo "session=xbmc" >> /etc/lxdm/default.conf
echo "lang=en_GB" >> /etc/lxdm/default.conf
exit
