Full Version: PLEASE HELP - Cannot launch SUDO anymore.
I am using XBMCbuntu Frodo RC3.
Since this morning, I cannot launch the command SUDO anymore.
The error I am getting is:
xbmc@xbmc-ThinkCentre-A55:~$ sudo su
[sudo] password for xbmc:
xbmc is not in the sudoers file.  This incident will be reported.
I checked the groups I belong to and:
xbmc@xbmc-ThinkCentre-A55:~$ groups
xbmc ftp
I'M QUITE DESPERATE!
How can I get back control of my machine?
How can I login as root?
Please help!!
su - root
(2013-01-20, 14:19)DYKWIA Wrote: [ -> ]su - root
but what is the root password?
Add xbmc user to video audio and sudo groups
usermod --group adm,cdrom,sudo,audio,video,plugdev,users fuse xbmc
You probably need to sign in as root to do that or edit the groups file manually. idk dont ask.
uNi
(2013-01-20, 15:19)uNiversal Wrote: [ -> ]Add xbmc user to video audio and sudo groups
uNi
Hi uNi,
what is the root password of XBMCbuntu?
I tried: <blank>, root, xbmc, toor. None of them worked.
thanks
Probably none is set
passwd root
Failing this idk, I dont even know how you managed to bork xbmc user groups
uNi
(2013-01-20, 15:38)uNiversal Wrote: [ -> ]Probably none is set
passwd root
uNi
here the result:
xbmc@xbmc-ThinkCentre-A55:~$ passwd root
passwd: You may not view or modify password information for root.
what can i do next?
what about safe mode?
I managed to enter in recovery mode and reset the root password.
thanks to all.
Its ridiculous that people actually do or encourage people to use sudo su.
WTF is wrong with sudo? There is a reason its setup this way (and you found out why...the hard way).
Quit being LAZY!
