Full Version: Asrock Gigabit Ethtool!
Just to ensure it is driver related or hardware issue!
Anyone running an Asrock ION 330 with Gigabit lan and can set at 100mbit? if i force with ethtool at 1000 full duplex the system loses network connectivity and putty loses connection!
I was sure it worked before? maybe under windows?
Are you turning autonegotiation off prior to setting speed and duplex?
sudo ethtool --change eth0 autoneg off speed 100 duplex full
crappy cat5e cable run i think... grrrr so frustrating and so bloody simple!
stipulated 350mhz on the cabling ended up being 100mhz... so all my frustration due to some lazy bugger with the wrong ticket gun!
