When i add the movie folder to the XBMC i can see the movies in the MOVIES !!!
When sometimes it works the XBMC does not pick up all of the movies from the folder (ATV2- NAS (smb)
grrrrr :S
what can i do?
here is my log file from today:
https://dl.dropbox.com/u/7542608/xbmc.log
the xbmc searched again when i started it, but have not find new movies (there are on the folder more then 130, and it takes to the media library 95 :S)
(i named all the files and folders well by the rules of the xbmc wiki site)
Turn on system->system->debugging and post a new log.
have a look into that log - you see the movies which it failed to scrape (because the used scraper sitedidn't find any information). You also see which url is used to query the scraper - just enter that url in a browswr and it should show you "no results" there too - now alterthe movie nam ein the url until the browser shows you the movie info you want - after that - remove your movies to that name ...
the problem is that the movies what are in log file and signed error, these are in the movie list of the xbmc :S
(if i open my movie folder in osx finder, there are cca. 140 movies and the media layer are 106 :S)
other solution
so in your log is no mentioning of a missing movie at all?
