Full Version: Pre-emptive question: Upgrading RC to final
Hi there,
I waited for the longest time before installing Frodo RC3, hoping that the final release would hit before I was forced to upgrade to use the NHL Gamecenter add-on. Unfortunately the NHL season started and no final version had appeared so XBMCbuntu RC3 was used. I did a clean install for various reasons and spent a bunch of time rescanning my library etc, so my question now is: Will it be possible to fully upgrade from RC3 to final (or a later RC) without doing another clean install? By fully, I mean get everything - the underlying OS as well as the XBMC app - to the same state as a fresh install?
Thanks a lot for any input.
yes
