2013-01-21, 16:21
So i have been working on this project all weekend. As you can see from my signature all of my machines are running the same version of FRODO to help avoid having some strange conflicts.
The machine in question is my mac mini which i set up to do all the heavy lifting due to its configuration. The problem that im having is a weird one, if i point the machine back to itself using an AFP share to the folder in question and that folder is blank, XBMC will create the Thumbnails folder and its blank structure. Then i have to remove the movie source and rebuild the DB so that it can begin populating the images. After that, it seems as if the same machine that created the images, can no longer write to that location (local on the machine) and i dont get any images in XBMC that should be coming from that location.
Here is my substitution line in my advancedsettings.config file:
<pathsubstitution> -<substitute> <from>special://masterprofile/Thumbnails/</from> <to>afp://192.168.1.25/ROOT/XBMC_IMG/Thumbnails/</to> </substitute> </pathsubstitution>
So i have a fully populated image folder yet i see no images in XBMC for my movie data. Whats up with that?
