Full Version: Advanced Launcher - Project 64
Hey guys,
I am using advanced launcher to launch project 64. It all works perfectly except that there's no sound!
The sound works perfectly if I launch project 64 outside of XMBC.
Debug Log
Launcher.xml
Additionally some games load a black screen when launched from within xmc but are fine outside of it.
Any ideas greatly appreciated!
Thanks,
Max
Managed to fix it, came across a program called auto it which is used to close xbmc for ps2 emulators and applied it for pj64, in fact it works for all programs much better than the pssuspend method found in most forums for this sort of thing.
Full details of how to do it can be found here:
http://www.gwenael.org/xbmc/index.php?title=PCSX2
Hope it helps someone!
p.s. your antivirus will probably report your file as a virus, but dont worry - its just a false positive!
Max
