Full Version: web interface
Hello folks,
I can't seem to find the option to enable the use of the web interface in the "Services" tab (or anywhere else). wiki says the option should be there but it is not. There's an error in the debug log, but not much else: DEBUG: Error: Requested setting (services.webserverport) was not found. It must be case-sensitive.
I'm currently running XBMC v11 on Slackware 14.0, 64bit, compiled with the slackbuilds.org script with the --enable-webserver flag. Is there anything I should know or do?
I'll give "Frodo" a try later tonight, meanwhile, any advices would be appreciated.
The pages have changed - looks like you are using Eden but following Frodo instructions.
In eden it is in Settings|Network
