2014-06-20, 04:12
2014-07-06, 13:51
Hi!
I love this add-on!
thank you very much!
just one question, I the plugin set to my photostream, and the random on setting on.
But it seems to randomize only the latest photos. is this a coincidence? or does it not find the older photos?
Thank you!
I love this add-on!
Thank you!
2014-07-10, 23:07
(2014-07-06, 13:51)Double_Digit Wrote: [ -> ]Hi!
I love this add-on!
Thank you!
Sorry I took so long to answer.
There is a limit of 500 photos per page on the flickr API. I could probably have it fetch multiple pages, but that is a lot more complex than just getting one page, which is why I haven't done it so far.
If I get a chance I may add that ability. I could also add a sort option, one of: date-posted-asc, date-posted-desc, date-taken-asc, date-taken-desc, interestingness-desc, interestingness-asc.
2014-07-13, 17:22
(2014-07-10, 23:07)ruuk Wrote: [ -> ](2014-07-06, 13:51)Double_Digit Wrote: [ -> ]Hi!
I love this add-on!
Thank you!
hey!
thanks for the awnser!
i thought of a workaround this which is using a tag on photos i want to display. That would make the "random" more evenlly spread through my photos. but when I go to to select the folders through tags, it only fetches the first 22 tags, alphabetically. Is this normal, or am I missing something?
2014-07-13, 18:38
(2014-07-13, 17:22)Double_Digit Wrote: [ -> ]hey!There may be a limit, but on mine I got a list of 286 tags. Are you sure you have more that 22 tags?
You can also use 'Search Photostream', but you will need to select 'Next Page' and then 'Previous Page' to get the search tags to be saved in the plugin path.
2014-07-13, 20:16
iThe thing is i cant get it to fully load. i press tags and it just hangs. at first i thought i was a internet speed issue, but afterr trying for 30m and 5 seconds, in all cases I end up pressing escape and it loads the 22 tags i mentioned earlier. the wierd thing is it always loads the same ones. either wating for long time, or almost nothing.
2014-07-13, 20:58
(2014-07-13, 20:16)Double_Digit Wrote: [ -> ]iThe thing is i cant get it to fully load. i press tags and it just hangs. at first i thought i was a internet speed issue, but afterr trying for 30m and 5 seconds, in all cases I end up pressing escape and it loads the 22 tags i mentioned earlier. the wierd thing is it always loads the same ones. either wating for long time, or almost nothing.
Maybe you should send me a log in case there is an error.
2014-11-10, 13:52
This only works if the plugin script is called default.py.
2014-11-10, 17:21
(2014-11-10, 13:52)Leopold Wrote: [ -> ]This only works if the plugin script is called default.py.You know, I almost certainly meant to add more generic handling to this, but forgot
Thanks for pointing this out. I'll fix it when I get the chance.
2014-11-10, 19:45
(2014-11-10, 17:21)ruuk Wrote: [ -> ]Thanks. I tried it with the Break Pictures plugin but all I saw was "ERROR: ShareSocial Not Installed"(2014-11-10, 13:52)Leopold Wrote: [ -> ]This only works if the plugin script is called default.py.You know, I almost certainly meant to add more generic handling to this, but forgot
2014-11-12, 19:46
Version 0.0.12
Changes:
On my REPO.
If anyone can also test this for me (it worked fine for me) then I'll push to the official repository.
Changes:
- Now works with plugins that don't use default.py
On my REPO.
2014-11-12, 22:20
Thanks. I'm trying to get this to work with the image plugin I recently wrote, but I now get this.
If you get a chance to look at this you can install it from http://ls80.github.io/xbmc.repo.leopold/...-0.5.0.zip to hopefully reproduce the error.
20:08:48 T:140573373609728 NOTICE: screensaver.plugin.slideshow: Showing 173 items
20:08:48 T:140573373609728 ERROR: Traceback (most recent call last):
20:08:48 T:140573373609728 ERROR: File "/storage/.xbmc/addons/screensaver.plugin.slideshow/pluginscreensaver.py", line 55, in onInit
20:08:48 T:140573373609728 ERROR: self.show(items)
20:08:48 T:140573373609728 ERROR: File "/storage/.xbmc/addons/screensaver.plugin.slideshow/pluginscreensaver.py", line 163, in show
20:08:48 T:140573373609728 ERROR: cur_img.setImage(items[-1]['url'])
20:08:48 T:140573373609728 ERROR: TypeError: string indices must be integers
20:08:48 T:140573373609728 NOTICE: screensaver.plugin.slideshow: ERROR: string indices must be integers
2014-11-13, 01:48
(2014-11-12, 22:20)Leopold Wrote: [ -> ]Thanks. I'm trying to get this to work with the image plugin I recently wrote, but I now get this.
Code:20:08:48 T:140573373609728 NOTICE: screensaver.plugin.slideshow: Showing 173 items
The new version should fix this, as well as make the screensaver work better with more plugins. Thanks for bringing this to my attention
2014-11-13, 13:46
(2014-11-13, 01:48)ruuk Wrote: [ -> ]The new version should fix this, as well as make the screensaver work better with more plugins. Thanks for bringing this to my attention
Thanks, it works well now with my plugin in Gotham 13.2.
With the Helix Beta 1 I still get the dancing "ERROR: ShareSocial Not Installed".
By the way, do you know how to make an image plugin itself display a caption, or just the item's label?
