2013-01-23, 12:29
Hi all,
first I really don't know if the question I'm about to ask is XBMC related, Backend related (DVBLink) or XMLTV related, but here it goes, I try here first.
For TV shows I record (set timer for in the PVR) they get a filename something like this (I'm at work and can't remember exacktly)
[Showname as in the EPG]-[StartTime]-[EndTime]-[Date].ts
Is it possible to have the following filename scheme (where applicable)?
[Showname]-S[SeasonNumber]E[EpisodeNumber]-[Additional info if needed].ts
It would make life a lot more simpler when using TheRenamer instead of looking up the Episode titel and match correct with thetvdb.com and manually rename the file, convert it and move it to the specific tv show folder
