Is it possible with the latest releases of XBMC/plugins to send a custom NOW PLAYING screen to Monitor 2? So when you choose a movie or music file to play it updates monitor 2 on the fly. A user over at avsforum (mcascio) did this with a software called mainLobby. I was wondering if it was possible with XBMC and maybe JSON calls or something..............
Someone set this up once with XBMC... I can't find the thread, though.
That's awesome (Anyone know what he has setup to display on that screen when XBMC is not running?)
He uses a program called mainLobby its a software suite you can help make custom menu's and stuff, looks complicated to me........ that's why I was wondering if xbmc can do this
Holy! this would be awesome!!! any update, can this be done
sure it can be done. now go do it.
Wish I had the expertize to do it!! Maybe in a few years when I have some programming knowledge I could do this but I am only learning.
SeveredDime That is it!!!! looks fantastic, I will check it out.
No problem, glad I could help.
I picked up 2 40" TV's for cheap off a local buy/sell site to use for this project. I believe it was in the works to have the program support multiple tv's, so I've been holding out waiting to see if that will be implemented. If not, from my understanding it won't be difficult to run two instances of the program at the same time, one for each display.
