Full Version: Entering music after having added some sources still brings you into files view
Problem: Entering the music window after having added some sources still brings you into the music files view and not into the library view because there's no default view yet for the music library. The user has to go one level up to be able to get into the music library views.
Solution: Go to the music library root view as soon as there is scanned content in the music library.
jmarshall Wrote:This is a problem due to no music_files_in_lib branch. Fix that and the rest is solved. Note that when music is scanned the Library/Artists etc. buttons are on Home under the Music item.
