(2013-01-25, 16:50)Memphiz Wrote: [ -> ]-1 thats not what suspend suggests.
(2013-01-26, 23:47)sho Wrote: [ -> ]If I suspend my PC, I would prefer it to resume in exactly the same state as it was when suspended.
Why would a media center behave differently?
Technically speaking I agree with you, this is how laptops and such devices behave. But IMO this is somewhat different.
If you close the lid on your laptop, it does make quite a bit of sense to leave the apps opened and as they where. However, with htpc's, atleast I but I suspect many, use it completely via the remote control. And using the red shutdown button on the remote to shutdown/start the device. The technical fact that its suspending, hibernating or shutdown is not really of interest, the intent is the same the only difference is speed (and in some cases the devices can't but turned on from hibernation or completely shutdown).
So I guess we could potentially break this out into the following 3 use cases:
1) User presses power button on remote and turns it back on in a few minutes or hours
2) User presses power button on remote and turns it back on the next day, week or month
3) User turns of TV but forgets to turn of the HTPC, it idles and suspends.
In 1 and 3 I completely agree it should pause, and pick up from where it was last. In 2, it might be valid to actually clear the stacks
One potential solution could be to reinvent it and steal some ideas from gnome 3:
In settings you choose what your power action should be, either "shutdown" or "pause". Then when we press the red button, xbmc will determine the best course of action to achieve this goal. I.e. "suspend" if pause is selected and suspend but clear stacks if "shutdown" is selected. So we decouple the technical aspect and the intent more.
Obviously we really need to have an easy way to choose this temporary and not redo the gnome 3 problem with only suspending unless you press some random button (alt).
Perhaps by having a "default shutdown action" in settings and in shutdown menu there are more options.
So remove all notion of "shutdown", "hibernate", "suspend" and "exit" and simply have "shutdown" and "pause" of some sorts. If --standalone we control the device power state also and without --standalone we don't control the state (behave as just an app).
Ideas?
Cheers,
Tobias
P.S. I agree we need to consider the network, hdmi devices and any other device (headphones or removable drives) which may have been added and removed during the suspend. But these should probably be another thread?
