Full Version: Issues after adding scraper HELP!!
I am new to XBMC so I don't completely know my way around the system.
Basically my library right now only consists of 3 movies and one full season of a TV show.
XBMC find the files perfectly but if I add a scraper the files disappear.
For example, after adding the source for my 3 movies I can easily navigate to them from video/movies in the XBMC system.
Once I add the scraper and navigate to videos/movies, the videos are not there.
I'm not sure what I am doing wrong and I would really appreciate the help
thank you
Welcome to the XBMC forums.
  • If you use the Videos > Files navigation path, are you able to locate your movie and TV show files?
  • Which scraper did you choose for your movies? For your TV shows?
  • Do you actually have these movies and TV shows scanned into your library? If so, you should see main menu items for "Movies" and "TV shows" (unless you had chosen to hide these menu options in your skin settings). Alternatively, when you highlight the main menu "Videos" item, you should see a "Library" option in the submenu displayed below it.
  • Do you have "Hide watched" enabled in your left slider menu and did you already watch these movies and TV shows?
