Full Version: XBMC will ask to disable an add-on if it is marked as broken in the repo
Problem: XBMC will ask to disable an add-on if it is marked as broken in the repo. If the add-on gets updated later on, I do not know because it has been disabled.
Solution: Prompt user when updates are available for disabled add-ons. Perhaps have a second category of disabled add-ons, one for when a user intentionally disables an add-on, and another one for when add-ons are disabled because they were marked as broken, and only check for updates on the later.
