(2013-06-25, 21:41)sarakha63 Wrote: [ -> ]it would be great to be able to delete or refresh if the image changed.
I changed a logo by another one and it never made the change untill i made my self in the replacement in the thumbnails cahce folder
Although not yet possible with this addon, you can force new artwork to be re-cached using the
Texture Cache Maintenance utility.
Run "./texturecache,py C sets" to force all movie set related artwork to be re-cached (posters, fanart, logos etc.). Add the partial name of a set to re-cache just the matching sets, eg. "./texturecache,py C sets potter" to re-cache just your Harry Potter set.
(2013-07-23, 18:38)Deano316 Wrote: [ -> ] (2013-06-19, 15:49)mikebzh44 Wrote: [ -> ]Yes. Logo is now OK.
I share my mod, if you (or someone else) is interested :
https://www.dropbox.com/s/iwib1dpcjst47z...-0.1.9.zip
Dude, that's awesome work......the final piece of the puzzle for me
Repworthy
Ok I downloaded the file, where do I put/save it so I can get it to work?
Wonderful.
Now to make things clear, in order for the addon to work with logos for movie sets, i assume u gotta reorder the folders, right? i mean, a common folder for a movieset, and all the movie folders in?
Logo work the same way as folder and fanart :
(2013-01-27, 04:44)trentf Wrote: [ -> ]You have the option of letting the script search for common parent folders of movies within a set and use folder.jpg and fanart.jpg files, or you can specify a single artwork folder containing artwork for all your movie sets (containing <set name>-folder.jpg and <set name>-fanart.jpg).
Example using common folders (movies stored in a single set folder)
\Blu-ray\Alien Anthology\Alien (1979) [BDRip] [1080p] [q18] [FLAC].mkv
\Blu-ray\Alien Anthology\Aliens (1986) [BDRip] [1080p] [q20] [FLAC].mkv
Example using common folders (movies stored in own folders under set folder)
\Blu-ray\Alien Anthology\Alien\Alien (1979) [BDRip] [1080p] [q18] [FLAC].mkv
\Blu-ray\Alien Anthology\Aliens\Aliens (1986) [BDRip] [1080p] [q20] [FLAC].mkv
Example using single artwork folder
\Blu-ray\Alien\Alien (1979) [BDRip] [1080p] [q18] [FLAC].mkv
\Blu-ray\Aliens\Aliens (1986) [BDRip] [1080p] [q20] [FLAC].mkv
Aaaw got it. It's cool. As soon i get home i'll check it.
(2013-06-17, 16:48)Kpitn Wrote: [ -> ]Hi,
I've a question : is it possible with your add-on to use HD logos with Movies Set ?
Like this :
Thank you
Which skin is this please.....and do you have to do something special to get a/ the discs and b/ the box set image instead of the single case?
Cheers Andy
It's Aeon Nox, the github version I believe.
Hi Trentf.
Did you have plan to push this addon on official repository ?
It works on ACE and other skins. So its cool.
I'm having a hard time getting this to work. I have all my movies grouped into sets via nfo set tag. When I press "I" on the movie set folder, it doesn't do anything. Also, when I try to navigate to movie>movie sets, I get a script error: plugin.py error. Any ideas what I'm missing here? Thanks.
