You can use tiny media manger to do most of it for you, combined with this add on
and just set up one folder for all your movieset art work
then use this add on, at the moment tiny media doesn't scrape movie set logo's but you can easily do this manually via fanart.tv
Hey toineb, I just saw that ur Dark Knight Trilogy poster opens into that 3 page brochure thing. How did you get that? Thanks for your help!
Sorry if it will be of topic, but do you know about plugin which allow to assign movie to movieset from within xbmc? I know it's possible with external software and nfo files, but I would prefer to do it from xbmc.
Gotham includes this as standard, just bring up the context menu and manage movie.
Is this working with the latest release of Gotham? I get a error when I run it .....
<class 'sqlite3.operationalError>
No such table: sets
The latest version shouldn't be using SQL on Gotham, it should be using JSON now - check you're on the latest version 0.2.2.
Says there's no update available but I believe it did say I was on 0.2.1. Can I update manually? Reason it's not showing a update available?
You have to update manually (from zip) - there's no automatic update facility as this addon isn't in a repository.
(2014-05-13, 20:14)MilhouseVH Wrote: [ -> ]You have to update manually (from zip) - there's no automatic update facility as this addon isn't in a repository.
Worked perfect thanks!
Hi;
Is possible add extrafanart1 for the background of moviesets cas?
Pretty sure extrafanart is just a directory of fanart relative to a parent directory.that skins know to look for, there is nothing written to the media library db so not sure what this addon is supposed to do.
