As Dev for Media Companion, and behinds the ball a bit, I'd like to advise that Media Companion 3.620b has support for Movie Set Artwork, from TMDB and Fanart.Tv.
XBMC Thread link
Media Companion Homepage - with links to Download, Discussionsm and Issue reporting.
I would appreciate anyone who wants to try Media Companion, to please give feedback in the XBMC Thread, or post issues on the Media Companion Homepage.
Thanks, and @
trentf and @
Milhouse, thanks for all the support and advise for Movie Set Artwork Automator.
So I finally got around to running this add-on on my live Kodibuntu and OSMC system, and found all my collections had no poster and no fanart.
Checking the MyVideo90.db file, I see that MSAA placed smb links for these files and they were malformed.
smb://NAS1/Volume_1/Multimedia/MovieSetArt//Rocky-fanart.jpg
smb://NAS1/Volume_1/Multimedia/MovieSetArt//Rocky-poster.jpg
Editing out the double forward slash to a single forward slash on a couple of sets, and Kodi started to display the artwork.
So I edited the MSAA settings file, changing the path to the single folder by removing the end forward slash, and ran it again.
Success!!
But, each time I leave the Movie Library, and return back, Kodi has to access the single folder for the Images.
I thought MSAA uploaded the images to Kodi's cache? or am I wrong?
Milhouse. Would Texturecache upload the artwork to Kodi Cache?
(2015-05-16, 03:24)vbat99 Wrote: [ -> ]@Milhouse. Would Texturecache upload the artwork to Kodi Cache?
Yes: "texturecache.py c sets" (or "C sets" to re-cache).
(2015-06-08, 20:31)Fail$tyle420 Wrote: [ -> ] (2015-05-23, 23:57)Fail$tyle420 Wrote: [ -> ] (2015-05-13, 22:19)Fail$tyle420 Wrote: [ -> ]and a BUMP
and a BUMPITY BUMP
BUUUUUUUUUUUUUUUUUUUUMP
the only way to do this is to use a keymap editor and to edit one of the keys to automatically run this add on. i do this with my harmony for artwork downloader where it is assigned to the yellow key on my remote.
(2015-06-17, 21:12)knives of ice Wrote: [ -> ] (2015-06-08, 20:31)Fail$tyle420 Wrote: [ -> ] (2015-05-23, 23:57)Fail$tyle420 Wrote: [ -> ]and a BUMPITY BUMP
I'll take a look at that, but I currently have artwork downloader being called by curl from eventghost and assumed it would be easy to do the same with this addon. The only reason I have that one working is because I found it here on the forums, but I wasn't able to just change the name to this addon.
How do yoy replace a fanart after you run the script for the first time?
I replaced the fie ran script, renamed the file ran script, deleted the file ran script and nothing happens.
thanks
You need to replace the fanart that is now in your texture cache - you can either wait several days for the background hash process to spot the change and automatically re-cache the updated artwork, or use the tool in my sig to forcibly re-cache artwork whenever required.
Try texture maintenance cache utility, that the easiest way i think.
Or remove an re add your library and re run movie set... (argh...)
(2015-04-28, 18:11)Ivabigone Wrote: [ -> ]Yes. The first page has following which are a bit out of date.....
Direct Download:
Eden: Version 0.1.0
Frodo/Gotham: Version 0.2.2
(2015-04-28, 18:20)komplex Wrote: [ -> ]It's not out of date "Frodo/Gotham: Version 0.2.2" works for the latest Kodi version
Might I suggest changing the first post so that it's obvious without needing to dig through pages of replies that it does indeed work with Helix.
Frodo/Gotham/Helix: Version 0.2.2
(2015-07-08, 23:17)pfp-az Wrote: [ -> ]Frodo/Gotham/Helix: Version 0.2.2
No need to stop at Helix - it works with Isengard and also J*****
Forgive me if I've miss-understood what this addon can do but should it share the art work I've chosen for sets over mysql to the other to machines I have running kodi? if so there not showing up any ideas? thanks
