Full Version: [FYI] xbmc.log
The wiki says xbmc.log can be found on
external storage/sdcard at: Android/data/org.xbmc.xbmc/files/.xbmc/temp/xbmc.log
well for some devices specialy the tv boxes its in
Root /Data/Data/org.xbmc.xbmc/Cache/temp/xbmc.log
you may need a root file explorer to find the log
Also to find Logcats just download the free app from google play .
Cheers
I recommend the "XBMC Log Uploader" which can be found in xbmc addon repo under programs.
Will note it. Sometimes the first folder even says "sdcard" when there is no SD card.
Thx for the update
