I'm running an iPad 2 iOS 5.1.1 running Xbmc 11 Eden, lately it's been running great with no issues until last night. Now when I try to open any media I have zero sound (audio still works outside xbmc) volume is not muted nor have I changed any settings
My log:
http://xbmclogs.com/show.php?id=30719
Any and all help is greatly appreciated
Post edited **debugging log added**
that is a crashreport - did it crash? i think you grabbed the wrong log. For what you describe we would need a
debug log (wiki)
You didn't try to open any media in that log file - nothing to be seen. Do a new log and try to play a video. Beside that "you didn't change anything" <- well we didn't either. So its unlikly that such problems come up when nothing was changed. Did you try to reboot the ipad (i mean a real power off).
Or did you install any wonky 3rd party apps which might run in the background and hog the audio device or something?
Problem solved apparently when u switch your mute switch to lock aspect ratio it can still mute the sound on xbmc
Thats a known bug in iOS - you need to diddle with the system settings where you switch between rotation lock and mute function and have the lock/mute switch "opened/unmuted" while changing its function.
