Full Version: Static custom Background for Main Menu Items
Hi, all i want (and trying now for hours) is to have custom Backgrounds for each Mainmenu Item. For Example: I scroll to Preferences and Background 1 shows, when i scroll to Search Background 2 shows etc. How can i make this happen guys? I dont want Slideshows, just a static background! Also i dont need a Dialog inside Xmbc to ask where the Background is or something i just want to write it in the xml files.
Just try my MOD
Tapatalked
In case there's uncertainty about which version to use: http://forum.xbmc.org/showthread.php?tid=147628
(Assuming Wunderwally is running XBMC Frodo since that's the version with contextual backgrounds removed from the default Confluence skin)
