Full Version: Resume and Comskip
Very impressed with how well the NPVR plugin works with Frodo. Skipping actually seems "snappier" than skipping in the NPVR client.
So far, the only features that I miss from the NPVR client are resume (across multiple clients) and comskip.
These may already be on the roadmap, but if not, how do put them up for consideration to be added to the official roadmaps for XBMC and/or NPVR (not sure which end is missing these features or if it's the protocol between the 2).
I do hope to add these in the future, but it's dependent on support for them being added in XBMC PVR framework.
If you play your files from TV Shows or the Video Library you will get resume and comskip with XBMC, and you can have multi client support using a MySQL database. Addition If you use the X-NEWA addon to play your files you get comskip too and also resume integration with NextPVR client.
Martin
