Full Version: HOW-TO Update local thumbnails for Frodo
Disclaimer: DO NOT TRY THIS WITHOUT TESTING FIRST! I make no guarantees that this will work. I can only say that it *might* mess up your whole system - and that's not my fault!
Ok, I was reading in the Wiki the XBMC v12 (Frodo) FAQ about the new/different thumbnails names. I haven't updated my system since Dharma so there's a fair bit of changes for me. Here's my old setup:
TV/
-The Simpsons
--season-all.tbn
--season-01.tbn
--The Simpsons.tbn
--Season 1/
---The Simpsons - S01E01 - Simpsons Roasting on an Open Fire.avi
---The Simpsons - S01E01 - Simpsons Roasting on an Open Fire.nfo
---The Simpsons - S01E01 - Simpsons Roasting on an Open Fire.tbn
etc... Frodo wants it to look like this:
TV/
-The Simpsons
--The Simpsons.tbn <--not needed
--Season 1/
So I got together a few bash commands to do most of the work:
change .tbn to .jpg/png
find . -type f -iname "*.tbn" | while read FNAME; do mv "$FNAME" "${FNAME%.tbn}.jpg"; done
rename "folder.jpg/png" to "poster.jpg/png"
find . -type f -iname 'folder.*' -print0 | xargs -0 -n1 bash -c 'mv "$0" "${0/folder/poster}"'
Rename "season-specials.jpg" to "season-specials-poster.jpg"
find . -type f -iname 'season*.jpg' -print0 | xargs -0 -n1 bash -c 'mv "$0" "${0/.jpg/-poster.jpg}"'
Having trouble with this one as OS X doesn't support -regextype in find and my QNAP doesn't even support -regex in find at all! I'm afraid it's going to take a perl script or something.
Remove "Show Name.jpg" from "Show Name/"
Haven't started on this one yet...
Many of these can be adapted easily for other types of renaming (use png instead of jpg, etc...) and I have executed these listed above against my own TV folders FWIW.
Just want to point out that you don't have to do that at all - Frodo will use the old ones just as well.
It may be preferred, but that's preference - up to the user.
Only ones that HAVE to change is VIDEO_TS/BDMV stuff which should be in the main folder, not in the VIDEO_TS/BDMV folder.
(2013-01-29, 04:33)jmarshall Wrote: [ -> ]Just want to point out that you don't have to do that at all - Frodo will use the old ones just as well.
Well that's great to know, thanks! I still prefer to use the new format as long as I'm setting up a new instance of XBMC too, might as well be forward-facing.
