Full Version: XBMC Favorites Help Please
Hello all, and thanks for reading. looking for a way or add-on that would let me make a favorites folder and sub folders.
example :
Folder Favorites
Sub folder :Cartoons, under cartoons all the favorites
Sub folder : Movies under movies subfolder xyz add favorites
so basicaly create a few folders and sub folders then when browsing xbmc ( file mode) choose whatever fav i want then a sub menu would appear with what folder to place it under.
i hope its clear. sorry for bad english
Thanks !
Hi all, any developer can make a addon that does this ? willing to pay for it
thanks!
Ok with xbmc 12 tag system I thought I can bypass favorites and add tags then make a playlist or something but the problem with tags is you can't use the tag function inter video-files .. Dunno what else to try Sad someone please help!
You could probably already do this using advanced library filtering.
Just put the favourites in a different physical location on the drive such as a /favourites folder.
