2013-03-15, 19:20
(2013-03-15, 15:47)GuiZ Wrote: [ -> ]@Khalos
In skin setting (last Git version)
Ok thx, but in horizontal layout I can't select it.
(2013-03-15, 14:22)Kahlos Wrote: [ -> ]And is see, that there is a little position error, see the screenshot.This one is fixed.
(2013-03-15, 14:22)Kahlos Wrote: [ -> ]And i found another error. When I activate weather-fanart in the skin settings and set the path to it, weather ("Wetter") appears two times in the main menu.But this one I can't re-create. Could you show me your guisettings.xml?
(2013-03-15, 17:34)GuiZ Wrote: [ -> ](2013-03-15, 16:57)saitoh183 Wrote: [ -> ](2013-03-12, 22:50)saitoh183 Wrote: [ -> ]just a heads up, Special characters like "é" and "è" dont show
was this fixed?
I have Special characters like "é" but no problem for me. (As you can see on the screenshot, in my last post)
Are you sure you use the défault font?
(2013-03-12, 21:34)paradix Wrote: [ -> ]Right now this icon is not integrated. I'll put it on the TODO list
(2013-03-13, 12:55)paradix Wrote: [ -> ]I intend to add the icon, but I was thinking about a different behaviour than in the confluence skin.
Confluence shows the icon whenever the movie is in progress, I would like to show the icon only if the movie is in progress and was never watched to the end (playcount = 0)
(2013-03-13, 22:23)keibertz Wrote: [ -> ]I wrote a german blog entry about my skin adaptations, see http://myxbmc.bplaced.net/blog/?p=736(2013-03-13, 21:29)john.doe Wrote: [ -> ]Could you tell us, how we can use your two views?At the moment i only know a german howto for this. http://www.xbmcnerds.com/index.php?page=...eadID=8995
xml in 720p and folders in extra?
folders in media ... but the Viewtype_PosterWrap3.xml is not Season ready yet. For Movies its working fine.
(2013-03-18, 11:52)john.doe Wrote: [ -> ]works perfect, any options to include it in svn version?
Quote:Integrating this views into the official version of the skin would require to change the theme of this views into the standard CEV3 themeWhat do u mean with theme ? which kind of changes do this include ? sure some skin options are required, but i dont know where the theme must be changed any more.
(2013-03-19, 14:17)keibertz Wrote: [ -> ]Quote:Integrating this views into the official version of the skin would require to change the theme of this views into the standard CEV3 themeWhat do u mean with theme ? which kind of changes do this include ? sure some skin options are required, but i dont know where the theme must be changed any more.
Quote:I would like to keep all available views in the same look and feel and not just paste different stuff together.ok this is not my point of view but i can understand that u think so. Than its a lot of work and the view will afterward not look like now.
