OK - quite possible a dumb question.
Loving the skin - was previously a Confluence MOD user as I needed the custom Home Menu items.
Upgraded to Gotham and Cirrus is doing everything as I want EXCEPT....
When I'm listening to music, is there a way to (skip to fullscreen mode?) so I can alter the volume with a simple Apple Remote (a la Confluence) rather than having to dig out the remote for my amp...?
hmm I'm not sure what you mean. How do you alter volume in Confluence? Can you explain a little bit closer.
Hi Paradix,
In Confluence, you can bring out the left side drawer, which has an option to listen to music 'fullscreen'
With this selected, I am able to alter the volume by pressing up or down on the remote.
That said, the urgency is gone as I've switched back to regular Confluence for the moment
Based on
http://wiki.xbmc.org/index.php?title=Apple_remote there is a global shortcut in the keymap of the Apple remote to switch to the Fullscreen --> Hold Play - Full Screen
This should solve your problem. I can't test it myself as I don't own a Apple remote.
Dear All,
i need your help! Since a couple of days im trying to get the soloution....
I'm using Cirrus Extended since 2 years. For me, its the best skin for xbmc.
Last week, i changed my system and updated some pc hardware. (Yeah, i forgot to backup my xbmc...)
I installed xbmc and i had downloaded the Gotham 13.1 Cirrus Extended skin.
So, until here all normal.
But at my new running xbmc system i have a problem with my TV Series - Season Fanarts.
Cirrus dont like to show there. Its only showing me the "all-season-fanart" - but if you click on the Season 1, 2, 3.. its showing the standart Cirrus Extended background...
Have anyone an Idee what happen and how i can show the seaons-fanarts?
I tested it on the Confluence skin, and there its work!
Its the first time, that that happens on xbmc...
Here i uploaded four screenshots, how it looks like:
CE All Season OK:
http://s14.directupload.net/images/140725/tdy6nth8.png
CE Season 1 FAIL:
http://s7.directupload.net/images/140725/eejmb7b7.png
Confl All Season OK:
http://s14.directupload.net/images/140725/9fdk7k2i.png
Confl Season 1 OK:
http://s14.directupload.net/images/140725/jljxqzl5.png
Can you show screenshots of all artwork set for "Alle Staffeln" and "Staffel 1"?
You can go there through the context menu and the option "Grafik wählen"
I would like to see something like this
http://prntscr.com/46bhs6
Btw I assume you are using artwork downloader?
EDIT:
There is probably a bug in the skin. QuickFix replace line 49 in Variables.xml with the following:
<value condition="Container.Content(TVShows) | Container.Content(Episodes) | Container.Content(seasons)">$INFO[ListItem.Art(fanart)]</value>
And delete the line 50.
Hey
I have a small glitch in the Right List Banner view in TV series:
Seems the lines are out of line...
It occurs in both versions, the one in the official repo and the one in the old repo.
Any ideas?
Rolf
Paradix,
Youre my hero!!
Its working fine now.
Thank you very much for your help!!!!
(2014-07-26, 13:08)Dingens Wrote: [ -> ]Hey
There seems to be a bug
I'll look into it and probably there will be a new version soon.
Cant see how you have custom sub menus with this
Is the following possible with this skin ?
I want
Movies
>Recently Added
>Sets
>Shortcut to Genesis (Which I want to name "Manage Movies")
>Genres
>Favorites
TV
>Recently Added
>Suggested Episodes
>Shortcut to Genesis (Which I want to name "Manage TV")
>Live TV
>Favorites
Settings
>Video Add Ons
>Programs
>File Manager
>Favorites
All in a Horizontal list
Problem with glitch in the Right List Banner view in TV series have been solved with 28/07/2014 update
