2014-10-14, 07:26
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46
2014-10-14, 13:17
2014-10-15, 02:34
(2014-10-14, 13:17)gates Wrote: [ -> ]or maybe, be patient
http://xbmc.org/downloads-and-the-addon-...n-tuesday/
I wish I saw that. Can't believe it never occurred to me to check the home page when I had issues downloading both advanced launcher and this. Would have saved me a lot of swearing at my wifi adapter.
2014-10-17, 14:22
Just a quick post to say, every 3-6 months I try all skin in order to find the best.
And guess what ?
I'm still using CEv3.
So Thank you Paradix for keeping it alive.
And thank you Butch to take CE so far (by the way i like your work on equilibrium ^^)
I have few request to improve CEv3.
But I know you dont have enough time. So I keep them in mind.
And guess what ?
2014-10-17, 19:02
gates I'm open to do any improvements in the skin. I'm just not that 'hardcore' skinner like butchabay
I always have problems with the graphics and the artistic part of designing a skin. The technical part is easy and I can do it all.
So pls post you ideas or PM me, I'll have a look and decide what can be done.
2014-10-19, 13:27
So there is a few ideas :
- add "recommended music" to (horizontal) home widget (currently, there is only last added).
- on the horizontal recommended tv-show widget, after playing an episode there is an update, the focus should be on the first item (and not on the last focus).
For example, you have 10 recommended tv-show, and you go on 4th item and play this episode, at the end of the episode, you return on the main screen :
=> if there is other ep of the same show, this show become the 1st recommended :
- your focus is on the 4th item, thats the old 3rd recommended
- probably, you want to watch the same show, and so get the focus on the 1st item
=> if there i no more unplayed ep from the show, the focus is still on the 4th item, thats the old 5th recommended. Tha make more sense to me that the old 2nd recommended who becommed the 1st get the focus.
- Add an "exit" buttom on music visualisation. Currently, the only way to exit is to stop the music (or maybe i miss something :x)
- Add an option in a tv-show/movie view (i guess right-list view is the best) to see the note and the number of vote
- A last crazy Idea . I know mikebzh44 make a script : http://forum.xbmc.org/showthread.php?tid...pid1658095 ( https://www.dropbox.com/s/wqw3mlduy64bjk...stitems.py )
this is for me a much better script than the skin.widget recommended for tv-show recommended.
This is THE script for all the anime/mangas watcher.
Currentlly i have to switch between 2 user profiles in order to have a widget for "traditionnal" tv-show and one for anime show.
Anyway if you can do this, i'll be grateful forever
Thx for caring
cheers
Thx for caring
cheers
2014-10-21, 14:07
(2014-10-19, 13:27)gates Wrote: [ -> ]- A last crazy Idea . I know mikebzh44 make a script : http://forum.xbmc.org/showthread.php?tid...pid1658095 ( https://www.dropbox.com/s/wqw3mlduy64bjk...stitems.py )
Thx for caring
cheers
For now I'll just comment on this one.
As I understand the skin, you already can use this script supplied by mikebzh44.
You need to use the Custom Home --> Custom Playlist 1-6 option, and than enable the widget for the latest shows for the proper playlist.
Maybe a setting for the recommended is missing. I'll have to think about it.
2014-10-23, 00:52
Ugh, I am fighting this skin and I wish there was some sort of "reset".
Somehow the default TV Show item on the home menu has changed to say "Display Artist Slideshow in music visualisation". I cannot for the life of me figure out where to change this. Selecting it takes me to my TV Shows section. I've looked up and down through the menus. I don't know how in the heck I got it to name it this way but I sure can't find out how to get it to go back.
Any help would be appreciated.
2014-10-24, 16:31
(2014-10-21, 14:07)paradix Wrote: [ -> ](2014-10-19, 13:27)gates Wrote: [ -> ]- A last crazy Idea . I know mikebzh44 make a script : http://forum.xbmc.org/showthread.php?tid...pid1658095 ( https://www.dropbox.com/s/wqw3mlduy64bjk...stitems.py )
Thx for caring
cheers
I dont use this script on CEv3 (but i would )
I Tried it on a Aeon Nox mod, it works
CEv3 already use this script with " Custom Home --> Custom Playlist 1-6 option => latest ep widget"
I've already replace the script by his mod in order to handle "recommended".
Now, I have to say to CEv3 to run this script with the proper parameters.
With Aeon Nox, the parameters take place in the guisetting.xml file, so i can easily change it.
For example :
PHP Code:
<setting type="string" name="skin.aeon.nox.SmartPlaylist4.Call">RunScript(script.randomandlastitems,type=Episode,playlist=special://profile/playlists/video/Mangas.xsp,method=Playlist,limit=10,recommended=True,property=SmartPlaylist4)</setting>
I've search a little in CEv3 guisetting option, but found nothing
So i guess it's in the skin it-self
2014-10-29, 15:14
I've found the <onload> in the startup.xml file.
I've edit the line for menu 4 to 6, and it works
now, I mod the right-list view, and the horizontal included for home widget.
2014-11-08, 20:29
mistake
2014-11-14, 09:35
Is anyone of the active users in this forum using the PVR section with this skin?
I'm working on the adjustments for Kodi Helix and need some beta testers to see if all is working right.
2014-11-14, 17:27
Hi paradix,
I use the PVR on this skin.
I dont want to install beta on my media center (openelec)
But i can test on my PC (Windows).
2014-11-14, 20:05
The latest Kodi Helix version can be downloaded from here --> http://1drv.ms/1EL56DF
2014-11-15, 00:07
Just tested, and seems OK.
The guide looks ugly, but works
