2014-02-12, 18:35
(2014-02-12, 18:30)Madmark555 Wrote: [ -> ]Thanks again for all this information.
I think my solution is optimal for my setup because the dac is inside the amp, so no analogic before the amp.
I will look into the slimserver plugin though, just curious.
If the slim server plugin for XBMC works for you, then you could use your same exact hardware. All you'd need to add is the slim server software on your HTPC, and let that handle the library organization of music files. There is a configuration option in the Slim Server software to "play back sound locally" so it would push the audio out your USB to the DAC.
