Full Version: File Stacking and Local Artwork
Hi All
I'm seeing the following on my V12RC3 install and was wondering if it is a bug or just me. For movies where I have multiple files, it appears that the scraper is bypassing local files and is scraping images from the web.
For example, I have the following structure
Movies (folder)
....The Lord of the Rings (folder)
........The Fellowship of the Ring (folder)
............The Fellowship of the Ring - CD1.mkv
............The Fellowship of the Ring - CD2.mkv
............The Fellowship of the Ring - CD1.nfo
When I add this to my library, the local poster and fanart are bypassed in favor of newly scraped images.
Try this if that works:
Cheers
I will give that a try. Guess this might end up as a bug on my metadata manager software rather than on XBMC...
Thanks Martijn, that did it all right. Time to submit a bug to MediaElch
(2013-01-30, 07:28)DecK Wrote: [ -> ]Thanks Martijn, that did it all right. Time to submit a bug to MediaElch
Great Smile
Same exact issue here.
renaming the fanart file to remove the ""CD1" worked for fanart.
Renaming the as per above, but also changed the tbn to a jpeg.
The old xbmc definitely didn't have that issue.
Talked too soon, I'm still having this issue which is 100% repeatable. Unsure, if this is the best place (post) to go into detail.
