Full Version: Upgraded to Frodo, but can't install xbmc-pvr-mythtv-cmyth
I'm running Ubuntu 11.10 (yes I know, but there is a reason) and just upgraded to Frodo. i was expecting to be able to run with the MythTV PVR addon, but I discovered it was not there. When I try to manually install it, I get:
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
xbmc-pvr-mythtv-cmyth : Depends: libmysqlclient18 but it is not installable or
                                  libmysqlclient15 but it is not installable or
                                  libmysqlclient14 but it is not installable
E: Unable to correct problems, you have held broken packages.
My system has libmysqlclient16 installed, so what's the problem? I even tried installing libmysqlclient16-dev to no avail.
