Full Version: season posters
I'm using Frodo RC3 with updated Aeon Nox. I've scraped with EMM (1.3.0.9) and a TV Show directory looks like this:
$ ls -al
total 1232
drwx------  1 mauzzz  staff   16384 29 jan 19:13 .
drwx------  1 mauzzz  staff   16384 22 jan 11:36 ..
drwx------  1 mauzzz  staff   16384 29 jan 16:18 Season1
drwx------  1 mauzzz  staff   16384 29 jan 16:18 Season2
drwx------  1 mauzzz  staff   16384 29 jan 16:18 Season3
-rwx------  1 mauzzz  staff   26549 29 jan 19:13 banner.jpg
-rwx------  1 mauzzz  staff  293268 29 jan 16:17 fanart.jpg
-rwx------  1 mauzzz  staff   26549 29 jan 16:17 poster.jpg
-rwx------  1 mauzzz  staff   68134 29 jan 16:17 season-all-poster.jpg
-rwx------  1 mauzzz  staff   37257 29 jan 16:18 season01-poster.jpg
-rwx------  1 mauzzz  staff   44643 29 jan 16:18 season02-poster.jpg
-rwx------  1 mauzzz  staff   33659 29 jan 16:18 season03-poster.jpg
-rwx------  1 mauzzz  staff    3951 29 jan 16:17 tvshow.nfo
In episode listing (episode view, poster enabled in viewtype settings) the season posters do not show up. I get (the same) poster.jpg in all seasons. However, the seasons posters are shown correctly in the season listing (list view).
Am I doing something wrong?
you need to use Artwork Downloader with Use local files set to On
(2013-01-29, 22:02)saitoh183 Wrote: [ -> ]you need to use Artwork Downloader with Use local files set to On
Won't work
i think ive got the same problem
maybe a flaw in aeon nox? @phil65
Well, I already have all artwork, EMM did that for me. I just need to figure out how to get it displayed correctly.
season poster are not available to skins on episode level anymore, except in the video info dialog.
(2013-01-30, 11:31)Big_Noid Wrote: [ -> ]season poster are not available to skins on episode level anymore, except in the video info dialog.
Then the poster toggle on/off in viewtype settings (while in episode listing) is obsolete?
(2013-01-30, 11:47)mauzzz Wrote: [ -> ]
No. If its obsolete to you, just toggle the poster off.
@Big_Noid
how about season fanart on episode level (lowlist) ??
this doesn't seem correct to me. I see my season poster and fanart just fine at an episode level. The great irony is I instead wish to see my episode poster and fanart, and I am stuck with seeing the season art instead.
(2013-02-01, 00:06)exoscoriae Wrote: [ -> ]this doesn't seem correct to me. I see my season poster and fanart just fine at an episode level. The great irony is I instead wish to see my episode poster and fanart, and I am stuck with seeing the season art instead.
what version of xbmc and aeon nox ??
Frodo stable with Aeon Nox v4.
I have the season posters and fan art in the shows root folder. Example names are poster: Season01.tbn, fan art:Season01-fanart.jpg.
(2013-02-01, 23:30)exoscoriae Wrote: [ -> ]Frodo stable with Aeon Nox v4.
OK, i have too the same way, the only difference is season01-poster.jpg. Works fine only navegating among seasons, but go down on episode level (low list) only displays the "default" poster and fanart instead of season poster and fanart.
I just dont know if was a change on xbmc or the skin...i dont mind to use a older version, but i need to know what causes this change...
When I get home I can take some screenshots to show you that my individual season posters are carrying down to the episode level.
