Hello! Need some help in here!
Anyone knows what is the maximum input that the board coming whit this case can handle?
It comes with a 60W power supply! It is just the power brick correct?
Can it handle a power brick with 12V and 10A?
Should be fine, but why not use the original power supply?
(2013-01-29, 22:12)R3mus Wrote: [ -> ]Hello! Need some help in here!
The standard OEM configuration for that case is a 120W DC powerboard and 84W AC adapter. If you can post the model number for the powerboard I can tell you for sure.
You can put in a 90A brick, the PSU will only pull the amps it needs.
bobo1on1, my current system is a A6-5400K wich is 65W!
Dougie Fresh and bobo1on1, according to MS-TECH it comes with "externem 60 Watt Netzteil".
So I would need another power brick for my system correct?
I can't post the powerboard number because I just wondering if I buy this case or not!
(2013-01-30, 14:46)R3mus Wrote: [ -> ]bobo1on1, my current system is a A6-5400K wich is 65W!
All they've repeated back to you is what you already know -- that it has an external 60W adapter. The A6-5400K just viewing the BIOS call pull 100W. The ones I get have a 120W powerboard and 84W AC adapter but they might get something different. It's strange they cannot answer your question.
(2013-01-30, 02:40)hick Wrote: [ -> ]You can put in a 90A brick, the PSU will only pull the amps it needs.
That's true, however if you have a short somewhere the cables and connectors will explode, so use a power supply that's not higher than the rated current of the connector and cables.
