Full Version: [WINDOWS] extrafanart for Music not working
I've tried looking around the forums but unfortunetly couldnt find an answer, apologies if this isnt in the right area.
I've never used extrafanart for Music Artists before but tried giving it a go in Frodo RC3.
My understanding on how the extrafanarts worked was that they are to be put into a folder "extrafanart" in the movie / artist folder. I've used Artwork Downloader for movies and then changed the background in Aeon Nox to extrafanart, which has worked and shows multiple images for each movie.
However, I've used the cdART manager to download extrafanarts for music artist, which created a "extrafanart" folder in the artists folder and successfully put the downloaded images there. But when I change the background in Aeon Nox it doesnt seem to pick up the extra fanarts.
Note that all files are all stored on a NAS and I have a windows machine setup with XBMC.
Not sure if this is the right way to do this.
Appriciate any help - Thanks
skin settings --> paths
Thanks Phil, fixed the issue - Never knew that was there!
