Full Version: Updating from Eden to Frodo failing
I've run through the command line install on the Wiki, and getting the following errors output from the ssh. Just to be helpful I've included how much free space there is at the bottom of the ssh log. I'm using Apple TV 2, currently on XMBC Eden, ios 5.1:
Stephens-MacBook-Air:~ stephenadams$ ssh [email protected]
[email protected]'s password:
Apple-TV:~ root# apt-get update
Ign http://mirrors.xbmc.org ./ Release.gpg
Hit http://cydia.zodttd.com stable Release.gpg
Hit http://apt.saurik.com tangelo-3.7 Release.gpg
Hit http://apt.modmyi.com stable Release.gpg
Hit http://apt.awkwardtv.org stable Release.gpg
Hit http://apt.thebigboss.org stable Release.gpg
Get:1 http://nitosoft.com Release.gpg [487B]
Ign http://mirrors.xbmc.org ./ Packages/DiffIndex
Get:2 http://apt.modmyi.com stable Release [1341B]
Hit http://nitosoft.com Release
Hit http://mirrors.xbmc.org ./ Packages
Err http://nitosoft.com Release
Hit http://cydia.zodttd.com stable/main Packages/DiffIndex
Hit http://apt.awkwardtv.org stable/main Packages/DiffIndex
Hit http://apt.thebigboss.org stable/main Packages/DiffIndex
Hit http://apt.modmyi.com stable/main Packages/DiffIndex
Get:3 http://nitosoft.com Release [295B]
Ign http://apt.saurik.com tangelo-3.7/main Packages/DiffIndex
Ign http://nitosoft.com Release
Hit http://apt.saurik.com tangelo-3.7/main Packages
Ign http://nitosoft.com Packages/DiffIndex
Hit http://nitosoft.com Packages
Fetched 2123B in 4s (456B/s)
Reading package lists... Done
W: GPG error: http://nitosoft.com Release: The following signatures were invalid: KEYEXPIRED 1355702829 KEYEXPIRED 1355702829 KEYEXPIRED 1355702829
Apple-TV:~ root#
Apple-TV:~ root# apt-get install org.xbmc.xbmc-atv2
Building dependency tree
Reading state information... Done
The following packages will be upgraded:
org.xbmc.xbmc-atv2
1 upgraded, 0 newly installed, 0 to remove and 15 not upgraded.
Need to get 45.4MB of archives.
After this operation, 0B of additional disk space will be used.
WARNING: The following packages cannot be authenticated!
org.xbmc.xbmc-atv2
Install these packages without verification [y/N]?
E: Some packages could not be authenticated
Apple-TV:~ root# chown -R mobile:mobile /private/var/mobile/Library/Preferences/XBMC/
Err http://apt.saurik.com tangelo-3.7 Release.gpg
NetDB: Open nodename nor servname provided, or not known
Ign http://apt.saurik.com tangelo-3.7 Release
Err http://apt.saurik.com tangelo-3.7/main Packages
Fetched 2123B in 4s (476B/s)
W: Failed to fetch http://apt.saurik.com/dists/tangelo-3.7/Release.gpg NetDB: Open nodename nor servname provided, or not known
W: Failed to fetch http://apt.saurik.com/dists/tangelo-3.7/...ackages.gz NetDB: Open nodename nor servname provided, or not known
E: Some index files failed to download, they have been ignored, or old ones used instead.
Apple-TV:~ root#
org.xbmc.xbmc-atv2
org.xbmc.xbmc-atv2
Apple-TV:~ root# df -k
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/disk0s1s1 697024 615840 74216 90% /
devfs 26 26 0 100% /dev
/dev/disk0s1s2 7085376 1044792 6040584 15% /private/var
Apple-TV:~ root# reboot
Apple-TV:~ root# Connection to 192.168.1.64 closed by remote host.
Connection to 192.168.1.64 closed.
Anyone help?
when it asks "Install these packages without verification [y/N]?" you need to hit "y".
i dont get the option to hit Y, it just jumps to the next line without letting me try:
org.xbmc.xbmc-atv2
Apple-TV:~ root# Y
-sh: Y: command not found
i was getting that error also when i was copying/pasting the commands. when i typed them myself it worked though. im guessing it was adding an extra enter key or something that was screwing it up. this was using putty.
Manged to fix it by installing NitoTV and upgrading through that. Think you're right about the extra enter key though
