2014-12-04, 01:38
My bad looks like I running Gotham. I will download Kodi and see how that works. I assume the updated Screensaver add-on is linked to the version Kodi vs Gotham?
(2014-12-04, 01:38)lowjumpingfrog Wrote: [ -> ]My bad looks like I running Gotham. I will download Kodi and see how that works. I assume the updated Screensaver add-on is linked to the version Kodi vs Gotham?
(2014-12-05, 23:38)arjones67 Wrote: [ -> ]Hello. I know the BoxeeBox is not an officially supported platform at the moment, but has any testing been done with this add-on the BoxeeBox? It's mostly working for me with 1 issue. About 10% of the time the images do not display correctly. I get a black background with white blocks. I'm running XBMC Gotham. I think I'm using version 1.09 of the add-on, but i'm not in front of the BoxeeBox at the moment to confirm. I'm trying to determine if there is a problem with my images or if it's a add-on/Boxee compatibility issue. My best guess is an add-on/Boxee issue because it does not appear to be related to specific images. Sometimes an image works and sometimes it doesn't.
I have no problem with Gotham and the add-on when running it on my Macbook Pro with the same images.
(2014-12-06, 01:42)ronie Wrote: [ -> ](2014-12-05, 23:38)arjones67 Wrote: [ -> ]Hello. I know the BoxeeBox is not an officially supported platform at the moment, but has any testing been done with this add-on the BoxeeBox? It's mostly working for me with 1 issue. About 10% of the time the images do not display correctly. I get a black background with white blocks. I'm running XBMC Gotham. I think I'm using version 1.09 of the add-on, but i'm not in front of the BoxeeBox at the moment to confirm. I'm trying to determine if there is a problem with my images or if it's a add-on/Boxee compatibility issue. My best guess is an add-on/Boxee issue because it does not appear to be related to specific images. Sometimes an image works and sometimes it doesn't.
not very likely to be an addon problem.
you could start by checking if the images display correctly in the pictures section of Kodi.
(2014-12-07, 18:22)aktarus Wrote: [ -> ]Hello,
Everythings was perfect with this slideshow screensaver since latest 1.0.9 version ... I was very happy
But Suddently this morning...no more screensaver![]()
When It want to lunch, I got a error "Erreur Echec du plugin: slideshow" (my xbmc is in french)
So I didn't change anything between the time it worked and now !! What's wrong with my xbmc ??
I'm running on the latest version of Gotham and latest version of slideshow !!
MERCI BEAUCOUP
(2014-12-08, 02:34)aktarus Wrote: [ -> ]Hello,
Here you can download two log file to see what's happened with it..
I setup start to 1 minute.. when slideshow suppose to start, I got the "script error"
The screen become black ans everything except slideshow seem to work well (music playbak)
When I click "esc" on keyboard, Black screen gone and I return to home screen like supposed..
https://dl.dropboxusercontent.com/u/16822683/xbmc.log
https://dl.dropboxusercontent.com/u/1682...mc.old.log
Please help me because I really lover this screensaver !!
MERCI
Quote:18:51:16 T:1873765376 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.ImportError'>
Error Contents: No module named tlslite.utils
File "/mnt/internal_sd/Android/data/hk.minix.xbmc/files/.xbmc/addons/screensaver.xbmc.slideshow/default.py", line 12, in <module>
from utils import *
File "/mnt/internal_sd/Android/data/hk.minix.xbmc/files/.xbmc/addons/script.video.F4mProxy/lib/utils/cipherfactory.py", line 8, in <module>
from tlslite.utils import python_aes
ImportError: No module named tlslite.utils
(2014-12-09, 20:32)lowjumpingfrog Wrote: [ -> ]More information on this ...
If I set the "Amount of seconds to display each image" to anything less than 5 seconds no images appear. If I set it for 6 seconds or greater then the images display for that amount of time less 5 seconds, eg. if "Amount of seconds to display each image" = 7 seconds the image displays for 2 seconds and then the screen is blank for 5 seconds before the next image appears.
System setup:
Raspberry Pi Model B
OpenElec 4.97.1
Picture Slideshow Screensaver 2.0.10
Pastebin Log File
I see errors in the log file but, not sure what they mean with regard to the Screensaver
Any ideas where I might go next?
Quote:10:49:49 336.006378 T:2825008192 NOTICE: DecodeJpegToTexture: unable to decode to texture /storage/pictures/DSC00277.JPG 1620x1080
10:49:49 336.027863 T:2971661376 ERROR: COMXCoreComponent:ecoderEventHandler OMX.broadcom.image_decode - OMX_ErrorStreamCorrupt, Bitstream corrupt
(2014-12-10, 01:23)lowjumpingfrog Wrote: [ -> ]These images display just fine in the screensaver and in the Picture slideshow part of Kodi. In fact, the pictures in the Slideshow action from the Home Screen Picture menu display with a crossfade just perfectly. It is only the blank screen in between the images (displayed without error) on the Screensaver Slideshow that is a problem. I resampled the images to the screen resolution 1920x1200 and the blank screen in between images is almost no existent. I suspect the issue is that Picture Slideshow screen saver is using a software JPEG decoder and the the Home Screen Picture slideshow is using a hardware decoder. When the images are smaller the software decoder works faster and the delay between images is shorter. I think the bitstream corruption is nothing more than the software decoder did not finish the JPEG decoding in time for the screensaver app to us it.
