2014-12-16, 21:30
Hello, all of a sudden with new update (latest nigtlie and even RC3) the slideshow stopped showing pictures from sub directories. Is it a known bug?
(2014-12-16, 21:30)chumaj001 Wrote: [ -> ]Hello, all of a sudden with new update (latest nigtlie and even RC3) the slideshow stopped showing pictures from sub directories. Is it a known bug?
(2014-12-08, 02:55)ronie Wrote: [ -> ]that script.video.F4mProxy addon is doing some silly things that break the screensaver addon.
your only option is to get rid of it.
(2014-12-22, 14:44)richardb70 Wrote: [ -> ](2014-12-08, 02:55)ronie Wrote: [ -> ]that script.video.F4mProxy addon is doing some silly things that break the screensaver addon.
Hi Ronie,
I too fell foul to this issue recently. I'm a coder, but not in Python unfortunately, and I was trying to work out why your add-on is trying to import resources from a different add-on. Couldn't work it out, but it was late and I have kids so I'm permanently tired. Can you explain how this could happen, and if there's a simple way to "contain" your imports so both add-ons can co-exist?
Many thanks in advance. Great screensaver, by the way.
(2014-12-16, 23:26)ronie Wrote: [ -> ](2014-12-16, 21:30)chumaj001 Wrote: [ -> ]Hello, all of a sudden with new update (latest nigtlie and even RC3) the slideshow stopped showing pictures from sub directories. Is it a known bug?
there was a bug in older version of the screensaver.
make sure you're using v2.0.10
(2014-12-28, 14:10)aristofeles Wrote: [ -> ]This is a dumb question i'm sure, but I've lost a few hours searching for an answer.
I have a windows share with my pictures - \\server\pics
I can see those pics on XBMC, no problem.
How do I configure the slideshow to see this path? The only path that the addon sees are local folders.
I know it's possible because I have a year-old raspberry pi (with paspbmc) that I've configured this way, working great until now... but I cant remember how I did it.
PS: if I remember correctly I've use some kind of symlink, but now idea how to do it, just followed some guide. I'm a Windows user only
(2014-12-28, 16:23)ronie Wrote: [ -> ](2014-12-28, 14:10)aristofeles Wrote: [ -> ]This is a dumb question i'm sure, but I've lost a few hours searching for an answer.
you first need to go to the pictures section in kodi and add your share there (using the 'add pictures...' option).
(2015-01-07, 13:52)diddle Wrote: [ -> ]Small question.
Is it possible to configure the screen saver to only pan either horizontally OR vertically (w/o zoom) for pictures where the asepct ratio does not fit the screen? I mean in a way that never black borders appear? (Hope it's clear... not easy to describe w/o pictures)
So a panorama picture would simply pan horizontally, whereas a 3:2 picture would simply pan vertically on the 16:9 screen.
If not: would be a desired feature for me.![]()
Thx
Diddle
(2014-12-22, 18:00)ronie Wrote: [ -> ](2014-12-22, 14:44)richardb70 Wrote: [ -> ](2014-12-08, 02:55)ronie Wrote: [ -> ]that script.video.F4mProxy addon is doing some silly things that break the screensaver addon.
Hi Ronie,
i can't be of much help i'm afraid. as already said, the issue is the script.video.F4mProxy addon.
the fix is that the addon needs to expose all the libraries it provides under 1 unique name,
and not provide a handful of libraries under very common names.
(2015-01-07, 14:48)aktarus Wrote: [ -> ](2014-12-22, 18:00)ronie Wrote: [ -> ](2014-12-22, 14:44)richardb70 Wrote: [ -> ]Hi Ronie,
Hello everyone,
I really love this screensaver.. but I also need F4mProxy addon in my XBMC ...
Any way to use these two at the same time ?? I'm still on Gotham, so I run the 1.0.9 version.
MERCI
(2015-01-07, 14:15)ronie Wrote: [ -> ]there's no option to only pan horizontal/vertical though.
