Ronie, ty for the addon, it's been joy to use it
I'm hoping someone can explain to me a few things.
The option 'scale images full screen', does it actually do anything when effect is set to pan&zoom?
my logic was that if 'scale images full screen' is on, it will respect the borders while doing pan&zoom, so it never shows black space.
I presume this addon only feeds default slideshow, but i just wanted to check, if i view images in default slideshow using pan&zoom, most of the time it starts with zooming, but
when i preview screensaver using pan&zoom most of the time it starts and use panning, resulting in black areas on the screen.
Is this just randomness of pan&zoom or screensaver has some effect on how pan&zoom is used/initiated?
tnx
Ok, i manged to slow down general pan&zoom with <panamount> & <zoomamount> in advancedsettings.
Ronie, can you tell me if Screensaver looks into advancedsettings.xml for those values? I don't see any changes
(2017-03-14, 18:42)maeda Wrote: [ -> ]Ok, i manged to slow down general pan&zoom with <panamount> & <zoomamount> in advancedsettings.
nope, those settings don't apply to the screensaver.
(2017-03-14, 18:57)ronie Wrote: [ -> ]nope, those settings don't apply to the screensaver.
I see, thank you for the answer
If maybe other people would find this useful, would you consider it as a request feature at some point?
It could reduce black areas with option to slow down panning.
i'm not opposed to it...
if someone who's interested in this functionality would provide the necessary code i'll add it.
(2017-03-01, 20:14)GooseK Wrote: [ -> ]In case anyone else hits the same problem, batch resizing images to a maximum of 3840x2160 (4K) seems to be an effective workaround.
Does anyone know what's the quickest and easiest way to bulk resize a load of photos in Windows?
(2017-04-13, 15:35)Finchy Wrote: [ -> ] (2017-03-01, 20:14)GooseK Wrote: [ -> ]In case anyone else hits the same problem, batch resizing images to a maximum of 3840x2160 (4K) seems to be an effective workaround.
Photoshop File->Scripts->Image Process works great and it's easy to use.
If you have Photoshop - which is pretty expensive
If you want cheper way you can use freeware IrfanView which has bulk resize function.
Thanks guys, I'll have a look at those
I second the use of Irfanview. It's free, but you do want to be careful with the settings. Under File, go to Batch Conversion/Rename and then click the Use Advanced Options and really look through the settings and make sure you've got things set the way you want before you write over a bunch of your files!
Hi there,
I use Kodi / Picture Slideshow Screensaver on Android on a Wetek Core and have the following problem. I searched the forum but couldn't find any solution.
Picture Slideshow Screensaver will not kick in if I pause a movie in full screen mode. Instead, the generic Google Slide show is started. Picture Slideshow Screensaver will only work if I go back to the Kodi movies list or menu.
This is unfortunate, as the screen saver will almost only be needed on a paused movie. If I am not watching a movie, I will generally switch off the TV.
Thanks and best regards,
Rob
My photo collection often contains the same photos in both .JPG and .NEF (i.e.the RAW file) from my Nikon D7000 DSLR.
The .NEF files usually just show in a pixelated fashion.
Is the problem that Kodi (or the addon?) doesn't support the .NEF file format? or is it the size of the file (often around 20MB 4928x3264 resolution)?
I have installed the NEF codec onto my Windows PC running Kodi but it made no difference.
A little more investigation into aforementioned issue.
.NEF files are Nikon's RAW file format (NEF =
Nikon Electronic Format) and based on TIFF. Details on RAW files -
https://en.wikipedia.org/wiki/Raw_image_format
Environment: Kodi 17.1 (Estuary Skin) running on Windows 10 x64 PC (Core i7, 16GB RAM). Picture Slideshow Screensaver Addon 4.2.1 from default repository.
Debug log excerpt of a successful image load:
13:18:57.874 T:16232 DEBUG: ffmpeg[3F68]: [mjpeg] marker=d8 avail_size_in_buf=6176867
13:18:57.874 T:16232 DEBUG: ffmpeg[3F68]: [mjpeg] marker parser used 0 bytes (0 bits)
13:18:57.874 T:16232 DEBUG: ffmpeg[3F68]: [mjpeg] marker=e1 avail_size_in_buf=6176865
13:18:57.878 T:16232 DEBUG: ffmpeg[3F68]: [mjpeg] marker parser used 65533 bytes (524264 bits)
13:18:57.878 T:16232 DEBUG: ffmpeg[3F68]: [mjpeg] marker=db avail_size_in_buf=6111329
13:18:57.878 T:16232 DEBUG: ffmpeg[3F68]: [mjpeg] index=0
13:18:57.878 T:16232 DEBUG: ffmpeg[3F68]: [mjpeg] qscale[0]: 0
13:18:57.878 T:16232 DEBUG: ffmpeg[3F68]: [mjpeg] index=1
13:18:57.878 T:16232 DEBUG: ffmpeg[3F68]: [mjpeg] qscale[1]: 0
13:18:57.878 T:16232 DEBUG: ffmpeg[3F68]: [mjpeg] marker parser used 132 bytes (1056 bits)
13:18:57.878 T:16232 DEBUG: ffmpeg[3F68]: [mjpeg] marker=c0 avail_size_in_buf=6111195
13:18:57.878 T:16232 DEBUG: ffmpeg[3F68]: [mjpeg] Changing bps from 0 to 8
13:18:57.878 T:16232 DEBUG: ffmpeg[3F68]: [mjpeg] sof0: picture: 4928x3264
13:18:57.878 T:16232 DEBUG: ffmpeg[3F68]: [mjpeg] component 0 2:1 id: 0 quant:0
13:18:57.878 T:16232 DEBUG: ffmpeg[3F68]: [mjpeg] component 1 1:1 id: 1 quant:1
13:18:57.878 T:16232 DEBUG: ffmpeg[3F68]: [mjpeg] component 2 1:1 id: 2 quant:1
13:18:57.878 T:16232 DEBUG: ffmpeg[3F68]: [mjpeg] pix fmt id 21111100
13:18:57.887 T:16232 DEBUG: ffmpeg[3F68]: [mjpeg] marker parser used 17 bytes (136 bits)
13:18:57.887 T:16232 DEBUG: ffmpeg[3F68]: [mjpeg] marker=c4 avail_size_in_buf=6111176
13:18:57.887 T:16232 DEBUG: ffmpeg[3F68]: [mjpeg] class=0 index=0 nb_codes=12
13:18:57.887 T:16232 DEBUG: ffmpeg[3F68]: [mjpeg] class=1 index=0 nb_codes=251
13:18:57.887 T:16232 DEBUG: ffmpeg[3F68]: [mjpeg] class=0 index=1 nb_codes=12
13:18:57.887 T:16232 DEBUG: ffmpeg[3F68]: [mjpeg] class=1 index=1 nb_codes=251
13:18:57.887 T:16232 DEBUG: ffmpeg[3F68]: [mjpeg] marker parser used 418 bytes (3344 bits)
13:18:57.891 T:16232 DEBUG: ffmpeg[3F68]: [mjpeg] escaping removed 22969 bytes
13:18:57.892 T:16232 DEBUG: ffmpeg[3F68]: [mjpeg] marker=da avail_size_in_buf=6110756
13:18:57.892 T:16232 DEBUG: ffmpeg[3F68]: [mjpeg] component: 0
13:18:57.892 T:16232 DEBUG: ffmpeg[3F68]: [mjpeg] component: 1
13:18:57.892 T:16232 DEBUG: ffmpeg[3F68]: [mjpeg] component: 2
13:18:58.017 T:16232 DEBUG: ffmpeg[3F68]: [mjpeg] marker parser used 6087786 bytes (48702288 bits)
13:18:58.017 T:16232 DEBUG: ffmpeg[3F68]: [mjpeg] marker=d9 avail_size_in_buf=0
13:18:58.017 T:16232 DEBUG: ffmpeg[3F68]: [mjpeg] decode frame unused 0 bytes
13:18:58.060 T:16232 DEBUG: CImageLoader::DoWork - took 273 ms to load smb://ANTMICROSERVER/Photos/Charlie/140126 - Family lunch at Pymble\DSC_3211.JPG
Debug log excerpt of an image load that is pixelated:
13:18:17.980 T:16232 DEBUG: ffmpeg[3F68]: Probing tiff_pipe score:51 size:2048
13:18:17.980 T:16232 DEBUG: ffmpeg[3F68]: [tiff_pipe] Format tiff_pipe probed with size=2048 and score=51
13:18:17.988 T:16232 DEBUG: ffmpeg[3F68]: [tiff_pipe] parser not found for codec tiff, packets or times may be invalid.
13:18:17.991 T:16232 DEBUG: ffmpeg[3F68]: [swscaler] Forcing full internal H chroma due to input having non subsampled chroma
13:18:17.993 T:16232 DEBUG: CImageLoader::DoWork - took 324 ms to load smb://ANTMICROSERVER/Photos/Charlie/141223 - Coco in garden\DSC_3512.NEF
So my assumption here is quite simply that FFmpeg used in Kodi (FFmpeg 3.1?) does not support .NEF file format. Does this look correct?
Full Debug log here -
https://pastebin.ca/3804356
I've just moved to a Synology and it has the nasty habit of creating thumbs in my folder that I use a my screensaver, resulting in a really ugly slideshow. Is it possible to exclude folders (I know this has been asked before) or limit the slideshow to pictures of a minimum resolution?
