2013-01-31, 07:07
I've tried searching for others with a similar problem but I'm coming up empty. The first movie I watched after upgrading from RC2 to RC3 suddenly had subtitles on all scenes when the same movie never exhibited that behavior before. I checked the subtitle option while the movie was playing and it was set to "None". I then went into the audio menu and found that "Enable Subtitles" was unchecked. I toggled it on and off but it made zero difference.
Giving up, I reinstalled RC2 over RC3 and the subtitles went away, but could still be manually enabled in the audio menu. Because of this I simply stuck with RC2 until the release version. However, I find the issue present in the 12.0 release and still I see nobody else talking about it. I can reproduce the issue in two separate MKV files with embedded (Not hardcoded) subtitles. Both of these movies were watched on RC2 and prior and neither had the problem, but with RC3 or the release version I simply cannot disable the subtitles. Pressing "T" makes the prompt appear, going between English and Disabled, but no actual change occurs.
Thanks for any help in advance. I'm sure I'm just overlooking something stupidly simple but it's beyond me at this point.
