2013-02-01, 06:46
The goal of this feature would be to add a "Volume adjustment rate" option to the system settings. It would adjust the rate volume up/down buttons on keyboards or remotes would raise or lower the volume each button press.
Right now, the volume is only incremented by ~1pt/button press. previously it used a formula with similar results. So adjusting the volume in any noticeable way requires several several button presses. It is nearly impossible to lower the volume quickly.
The new volume adjustment setting may have the following values;
Nudge (the current value), 1%, 2%, 3%... Up to 20%.
At the highest setting, 5 buttons presses would go from mute to full volume. A good default might settle in the 5% range.
Thank you!
Thank you!
