Full Version: XBMC Remote v 1.0.9 Build 1009 issue
Hello everyone.
I found some problems after XBMC REMOTE upgrade.
- I cant start play folder if it contain subfolders with music.
- When I start play same files I cant select play one of them from "Now playing" -> "Playlist" (please see image). It's look like all of paylists elements deactivated.
- And also don't possible to forward and rewind by using tap. This element also deactivated. (please see screenshot). It's look like play nothing.
Are you connected to XBMC Eden (11)? The latest release of the remote is only fully compatible with Frodo (12).
No, I'm connect to Frodo. I also try to reinstall application (even remove xbmc folder from SD card) bun nothing change.
