Full Version: Add-on to automatically generate local nfo files?
Good morning everyone - thanks for all your hard work - I love this platform and use it on 4 machines in our house.
I am wondering if anyone is aware of a program add-on that would automatically export the video library into the content directories and generate the nfo files.
ie - this would do the same thing as /system/settings/video/library/export video library/separate files
When you backup like this it is very easy for another computer to grab and index the content because the artwork and nfo files are locally stored.
Problem is you have to manually do this every now and then when it would be nice if that was something that occurred daily at a certain time.
This is different then XBMC Backup plugin operation which is more for backing up content.
Thanks for your advice
Chris
