2013-02-02, 05:30
Operating System: Windows 7 ultimate 64bit
Tuner: Asus pe9400 combo
IR Remote: MCE Certified Remote
IR Transmitter/Receiver: Unknown Brand OVU412003/DB
Here is my tuner and remote from newegg
Cable Provider: Comcast
PVR Software: Mediaportal
I actually have two issues......I have comcast as a cable provider so i have to have a cable box because the channels are encrypted. Therefore I need to be able to use my blaster to change the channel of the comcast box. I have tried using the IR Server Suite my box is not preloaded in the config files of the IR Server Suite I was trying to follow this guide on how to train the software. http://www.techlifeweb.com/2010/12/27/ho...ia-center/ but when I try to connect with the IR File Tool it just reads "connecting". Am i doing something wrong?
My second issue is I will then be looking for a good way to load these channels that i can't scan with my tuner. Do i have to do this manually is there an easier way to do that?
Thank You
Quick Addition
I did get the blaster to work in windows media center if that makes a difference
Thank You
Quick Addition
