Full Version: Xbmc freezes when enabling AirPlay
Whenever i try to enable AirPlay Xbmc freezes and I have to reboot. The debug doesn't say anything interesting as far as I can tell:
09:24:08 T:139844027914048   DEBUG: OnKey: 11 (0b) pressed, action is Select
09:24:08 T:139844027914048    INFO: AIRPLAY Server: Successfully initialized
09:24:08 T:139843019450112  NOTICE: Thread AirPlayServer start, auto delete: false
09:24:08 T:139843729254144  NOTICE: Thread Jobworker start, auto delete: true
09:24:08 T:139844027914048   DEBUG: SECTION:LoadDLL(libshairport.so.0)
09:24:08 T:139843729254144   DEBUG: CZeroconfAvahi::doPublishService identifier: servers.airplay type: _airplay._tcp name:Neo port:36667
09:24:08 T:139843729254144   DEBUG: CZeroconfAvahi::addService() named: Neo type: _airplay._tcp port:36667
09:24:08 T:139844027914048   DEBUG: Loading: libshairport.so.0
09:24:08 T:139843011057408  NOTICE: Thread AirTunesServer start, auto delete: false
09:24:08 T:139843729254144   DEBUG: CZeroconfAvahi::doPublishService identifier: servers.airtunes type: _raop._tcp name:90E6BAA63BEA@Neo port:36666
09:24:08 T:139843729254144   DEBUG: CZeroconfAvahi::addService() named: 90E6BAA63BEA@Neo type: _raop._tcp port:36666
09:24:08 T:139843027842816  NOTICE: Thread Jobworker start, auto delete: true
09:24:08 T:139844027914048   DEBUG: LIRC: Update - NEW at 144707:160 0 KEY_OK_UP devinput (KEY_OK_UP)
09:24:09 T:139843354994432   DEBUG: CZeroconfAvahi::groupCallback: Service successfully established
09:24:09 T:139844027914048   DEBUG: Previous line repeats 1 times.
09:24:09 T:139844027914048   DEBUG: CPlayerCoreFactory::GetPlayers(pipe://1/)
09:24:09 T:139844027914048   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: system rules
09:24:09 T:139844027914048   DEBUG: CPlayerSelectionRule::GetPlayers: matches rule: system rules
09:24:09 T:139844027914048   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: rtv
09:24:09 T:139844027914048   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: hdhomerun/myth/mms/udp
09:24:09 T:139844027914048   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: lastfm/shout
09:24:09 T:139844027914048   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: rtsp
09:24:09 T:139844027914048   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: streams
09:24:09 T:139844027914048   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: dvd
09:24:09 T:139844027914048   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: dvdimage
09:24:09 T:139844027914048   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: sdp/asf
09:24:09 T:139844027914048   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: nsv
09:24:09 T:139844027914048   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: radio
09:24:09 T:139844027914048   DEBUG: CPlayerCoreFactory::GetPlayers: matched 0 rules with players
09:24:09 T:139844027914048   DEBUG: CPlayerCoreFactory::GetPlayers: adding audiodefaultplayer (3)
09:24:09 T:139844027914048   DEBUG: CPlayerCoreFactory::GetPlayers: for video=0, audio=1
09:24:09 T:139844027914048   DEBUG: CPlayerCoreFactory::GetPlayers: adding player: PAPlayer (3)
09:24:09 T:139844027914048   DEBUG: CPlayerCoreFactory::GetPlayers: for video=1, audio=1
09:24:09 T:139844027914048   DEBUG: CPlayerCoreFactory::GetPlayers: adding player: DVDPlayer (1)
09:24:09 T:139844027914048   DEBUG: CPlayerCoreFactory::GetPlayers: added 2 players
09:24:09 T:139844027914048   DEBUG: DllAvUtilBase: Using libavutil system library
09:24:09 T:139844027914048   DEBUG: FactoryCodec - Audio: passthrough - Opening
09:24:09 T:139844027914048   DEBUG: FactoryCodec - Audio: passthrough - Failed
09:24:09 T:139844027914048   DEBUG: FactoryCodec - Audio: pcm - Opening
09:24:09 T:139844027914048   DEBUG: FactoryCodec - Audio: pcm - Opened
+1 same issue here. Frodo + Aeon MQ4 + Ubuntu Desktop 12.04 LTS.
After playing through Airplay, there is no way to play local file. Xbmc crash.
Can we get full debug logs (wiki) from you guys?
i bet you guys are using the wrong libshairport version - use the one from our ppa ...
Same problem, windows7-64 XBMC12
When I start on my Iphone playing a mp3 and I change the player to XBMC than the view changes on XBMC screen "to airplay" but XBMC freezes. When I stop playing the mp3 on my iphone the freeze is ended and XBMC works normal.
20:40:24 T:4828 NOTICE: Enabled debug logging due to GUI setting. Level 2.
20:40:24 T:4828 DEBUG: ------ Window Init () ------
20:40:29 T:4828 DEBUG: Activating window ID: 12006
20:40:30 T:4828 DEBUG: ------ Window Deinit (SettingsCategory.xml) ------
20:40:30 T:4828 DEBUG: ------ Window Init (MusicVisualisation.xml) ------
20:40:30 T:3292 DEBUG: CAnnouncementManager - Announcement: OnVolumeChanged from xbmc
20:40:30 T:3292 DEBUG: GOT ANNOUNCEMENT, type: 64, from xbmc, message OnVolumeChanged
20:40:30 T:4828 DEBUG: CPlayerCoreFactory::GetPlayers(pipe://2/)
20:40:30 T:4828 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: system rules
20:40:30 T:4828 DEBUG: CPlayerSelectionRule::GetPlayers: matches rule: system rules
20:40:30 T:4828 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: rtv
20:40:30 T:4828 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: hdhomerun/myth/mms/udp
20:40:30 T:4828 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: lastfm/shout
20:40:30 T:4828 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: rtsp
20:40:30 T:4828 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: streams
20:40:30 T:4828 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: dvd
20:40:30 T:4828 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: dvdimage
20:40:30 T:4828 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: sdp/asf
20:40:30 T:4828 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: nsv
20:40:30 T:4828 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: radio
20:40:30 T:4828 DEBUG: CPlayerCoreFactory::GetPlayers: matched 0 rules with players
20:40:30 T:4828 DEBUG: CPlayerCoreFactory::GetPlayers: adding audiodefaultplayer (3)
20:40:30 T:4828 DEBUG: CPlayerCoreFactory::GetPlayers: for video=0, audio=1
20:40:30 T:4828 DEBUG: CPlayerCoreFactory::GetPlayers: adding player: PAPlayer (3)
20:40:30 T:4828 DEBUG: CPlayerCoreFactory::GetPlayers: for video=1, audio=1
20:40:30 T:4828 DEBUG: CPlayerCoreFactory::GetPlayers: adding player: DVDPlayer (1)
20:40:30 T:4828 DEBUG: CPlayerCoreFactory::GetPlayers: added 2 players
20:40:30 T:4828 DEBUG: FactoryCodec - Audio: passthrough - Opening
20:40:30 T:4828 DEBUG: FactoryCodec - Audio: passthrough - Failed
20:40:30 T:4828 DEBUG: FactoryCodec - Audio: pcm - Opening
20:40:30 T:4828 DEBUG: FactoryCodec - Audio: pcm - Opened
20:40:47 T:4740 DEBUG: Thread Jobworker 4740 terminating (autodelete)
20:40:47 T:3932 DEBUG: Thread Jobworker 3932 terminating (autodelete)
20:40:52 T:4828 INFO: PAPlayer::QueueNextFileEx - Error reading samples
20:40:52 T:4828 DEBUG: CAnnouncementManager - Announcement: OnStop from xbmc
20:40:52 T:4828 DEBUG: GOT ANNOUNCEMENT, type: 1, from xbmc, message OnStop
20:40:52 T:4828 DEBUG: CGUIWindowManager:TonguereviousWindow: Deactivate
20:40:52 T:4828 DEBUG: ------ Window Deinit (MusicVisualisation.xml) ------
20:40:52 T:4828 DEBUG: CGUIWindowManager:TonguereviousWindow: Activate new
20:40:52 T:4828 DEBUG: ------ Window Init (SettingsCategory.xml) ------
20:40:52 T:3292 DEBUG: AIRTUNES: AirPlay not running - stopping player
20:40:52 T:4828 DEBUG: CWinEventsWin32::WndProc: window resize event
20:40:53 T:4828 DEBUG: ------ Window Deinit (Pointer.xml) ------
20:40:56 T:4828 DEBUG: ------ Window Init (Pointer.xml) ------
20:40:57 T:4828 DEBUG: CApplication:TonguerocessMouse: trying mouse action leftclick
20:40:57 T:4828 NOTICE: Disabled debug logging due to GUI setting. Level 0.
20:40:57 T:4828 NOTICE: Log level changed to 0
20:41:00 T:3092 NOTICE: Thread Jobworker start, auto delete: true
Same problem here too. I've got 2 PC's running Ubuntu 12.10 x64 with the latest Frodo 12.1.
Everytime I activate the AirPlay setting -> XBMC freezes.
I am using the latest libsharepoint:
Quote:XBMC.log
15:17:36 T:140312814794624 DEBUG: Keyboard: scancode: 72, sym: 0113, unicode: 0000, modifier: 0
15:17:36 T:140312814794624 DEBUG: CAnnouncementManager - Announcement: OnScreensaverDeactivated from xbmc
15:17:36 T:140312814794624 DEBUG: GOT ANNOUNCEMENT, type: 4, from xbmc, message OnScreensaverDeactivated
15:17:36 T:140312814794624 DEBUG: OnKey: right (f083) pressed, screen saver/dpms woken up
15:17:37 T:140312814794624 DEBUG: Keyboard: scancode: 72, sym: 0113, unicode: 0000, modifier: 0
15:17:37 T:140312814794624 DEBUG: OnKey: right (f083) pressed, action is Right
15:17:37 T:140312676226816 INFO: CAESinkALSA::Initialize - Attempting to open device "hdmi:CARD=NVidia,DEV=1"
15:17:37 T:140312676226816 INFO: CAESinkALSA::Initialize - Opened device "hdmi:CARD=NVidia,DEV=1,AES0=0x04,AES1=0x82,AES2=0x00,AES3=0x00"
15:17:37 T:140312676226816 INFO: CAESinkALSA::InitializeHW - Your hardware does not support AE_FMT_FLOAT, trying other formats
15:17:37 T:140312676226816 INFO: CAESinkALSA::InitializeHW - Using data format AE_FMT_S32NE
15:17:37 T:140312676226816 DEBUG: CAESinkALSA::InitializeHW - Request: periodSize 512, periods 16, bufferSize 8192
15:17:37 T:140311976191744 NOTICE: Thread Jobworker start, auto delete: true
15:17:37 T:140312676226816 DEBUG: CAESinkALSA::InitializeHW - Got: periodSize 512, periods 16, bufferSize 8192
15:17:37 T:140312676226816 DEBUG: CAESinkALSA::InitializeHW - Setting timeout to 186 ms
15:17:37 T:140312676226816 DEBUG: Resumed the Sink
15:17:38 T:140312814794624 DEBUG: ------ Window Deinit () ------
15:17:39 T:140312814794624 DEBUG: Keyboard: scancode: 72, sym: 0113, unicode: 0000, modifier: 0
15:17:39 T:140312814794624 DEBUG: OnKey: right (f083) pressed, action is Right
15:17:39 T:140312734947072 NOTICE: Thread Jobworker start, auto delete: true
15:17:40 T:140312814794624 DEBUG: Keyboard: scancode: 72, sym: 0113, unicode: 0000, modifier: 0
15:17:40 T:140312814794624 DEBUG: OnKey: right (f083) pressed, action is Right
15:17:41 T:140312814794624 DEBUG: Keyboard: scancode: 72, sym: 0113, unicode: 0000, modifier: 0
15:17:41 T:140312814794624 DEBUG: OnKey: right (f083) pressed, action is Right
15:17:43 T:140312814794624 DEBUG: Keyboard: scancode: 74, sym: 0112, unicode: 0000, modifier: 0
15:17:43 T:140312814794624 DEBUG: OnKey: down (f081) pressed, action is Down
15:17:44 T:140312814794624 DEBUG: Keyboard: scancode: 24, sym: 000d, unicode: 000d, modifier: 0
15:17:44 T:140312814794624 DEBUG: OnKey: return (f00d) pressed, action is Select
15:17:44 T:140312814794624 DEBUG: ExecuteXBMCAction : Translating ActivateWindow(Settings)
15:17:44 T:140312814794624 DEBUG: ExecuteXBMCAction : To ActivateWindow(Settings)
15:17:44 T:140312814794624 DEBUG: Activating window ID: 10004
15:17:44 T:140312814794624 DEBUG: ------ Window Deinit (Home.xml) ------
15:17:44 T:140312814794624 DEBUG: ------ Window Init (Settings.xml) ------
15:17:44 T:140312814794624 INFO: Loading skin file: Settings.xml, load type: KEEP_IN_MEMORY
15:17:45 T:140312814794624 DEBUG: Keyboard: scancode: 74, sym: 0112, unicode: 0000, modifier: 0
15:17:45 T:140312814794624 DEBUG: OnKey: down (f081) pressed, action is Down
15:17:46 T:140312814794624 DEBUG: Keyboard: scancode: 74, sym: 0112, unicode: 0000, modifier: 0
15:17:46 T:140312814794624 DEBUG: OnKey: down (f081) pressed, action is Down
15:17:47 T:140312814794624 DEBUG: Keyboard: scancode: 74, sym: 0112, unicode: 0000, modifier: 0
15:17:47 T:140312814794624 DEBUG: OnKey: down (f081) pressed, action is Down
15:17:48 T:140312814794624 DEBUG: Keyboard: scancode: 74, sym: 0112, unicode: 0000, modifier: 0
15:17:48 T:140312814794624 DEBUG: OnKey: down (f081) pressed, action is Down
15:17:50 T:140312814794624 DEBUG: Keyboard: scancode: 74, sym: 0112, unicode: 0000, modifier: 0
15:17:50 T:140312814794624 DEBUG: OnKey: down (f081) pressed, action is Down
15:17:52 T:140312814794624 DEBUG: Keyboard: scancode: 24, sym: 000d, unicode: 000d, modifier: 0
15:17:52 T:140312814794624 DEBUG: OnKey: return (f00d) pressed, action is Select
15:17:52 T:140312814794624 DEBUG: ExecuteXBMCAction : Translating ActivateWindow(ServiceSettings)
15:17:52 T:140312814794624 DEBUG: ExecuteXBMCAction : To ActivateWindow(ServiceSettings)
15:17:52 T:140312814794624 DEBUG: Activating window ID: 10018
15:17:53 T:140312814794624 DEBUG: ------ Window Deinit (Settings.xml) ------
15:17:53 T:140312814794624 DEBUG: ------ Window Init (SettingsCategory.xml) ------
15:17:53 T:140312814794624 INFO: Loading skin file: SettingsCategory.xml, load type: KEEP_IN_MEMORY
15:17:53 T:140312814794624 DEBUG: Keyboard: scancode: 74, sym: 0112, unicode: 0000, modifier: 0
15:17:53 T:140312814794624 DEBUG: OnKey: down (f081) pressed, action is Down
15:17:54 T:140312814794624 DEBUG: Keyboard: scancode: 74, sym: 0112, unicode: 0000, modifier: 0
15:17:54 T:140312814794624 DEBUG: OnKey: down (f081) pressed, action is Down
15:17:55 T:140312814794624 DEBUG: Keyboard: scancode: 74, sym: 0112, unicode: 0000, modifier: 0
15:17:55 T:140312814794624 DEBUG: OnKey: down (f081) pressed, action is Down
15:17:56 T:140312814794624 DEBUG: Keyboard: scancode: 74, sym: 0112, unicode: 0000, modifier: 0
15:17:56 T:140312814794624 DEBUG: OnKey: down (f081) pressed, action is Down
15:17:58 T:140312814794624 DEBUG: Keyboard: scancode: 72, sym: 0113, unicode: 0000, modifier: 0
15:17:58 T:140312814794624 DEBUG: OnKey: right (f083) pressed, action is Right
15:17:59 T:140312814794624 DEBUG: Keyboard: scancode: 24, sym: 000d, unicode: 000d, modifier: 0
15:17:59 T:140312814794624 DEBUG: OnKey: return (f00d) pressed, action is Select
15:17:59 T:140312814794624 INFO: AIRPLAY Server: Successfully initialized
15:17:59 T:140312814794624 DEBUG: SECTION:LoadDLL(libshairport.so.2)
15:17:59 T:140312814794624 DEBUG: Loading: libshairport.so.2
15:17:59 T:140312734947072 DEBUG: CZeroconfAvahi::doPublishService identifier: servers.airplay type: _airplay._tcp name:Steff-XBMC port:36667
15:17:59 T:140312734947072 DEBUG: CZeroconfAvahi::addService() named: Steff-XBMC type: _airplay._tcp port:36667
15:17:59 T:140311533610752 NOTICE: Thread AirPlayServer start, auto delete: false
15:17:59 T:140312709768960 NOTICE: Thread AirTunesServer start, auto delete: false
15:17:59 T:140311976191744 DEBUG: CZeroconfAvahi::doPublishService identifier: servers.airtunes type: _raop._tcp name:001D92DBC4C9@Steff-XBMC port:36666
15:17:59 T:140311976191744 DEBUG: CZeroconfAvahi::addService() named: 001D92DBC4C9@Steff-XBMC type: _raop._tcp port:36666
15:18:00 T:140312632088320 DEBUG: CZeroconfAvahi::groupCallback: Service successfully established
15:18:00 T:140312814794624 DEBUG: Previous line repeats 1 times.
15:18:00 T:140312814794624 DEBUG: CPlayerCoreFactory::GetPlayers(pipe://1/)
15:18:00 T:140312814794624 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: system rules
15:18:00 T:140312814794624 DEBUG: CPlayerSelectionRule::GetPlayers: matches rule: system rules
15:18:00 T:140312814794624 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: rtv
15:18:00 T:140312814794624 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: hdhomerun/myth/mms/udp
15:18:00 T:140312814794624 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: lastfm/shout
15:18:00 T:140312814794624 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: rtmp
15:18:00 T:140312814794624 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: rtsp
15:18:00 T:140312814794624 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: streams
15:18:00 T:140312814794624 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: dvd
15:18:00 T:140312814794624 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: dvdimage
15:18:00 T:140312814794624 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: sdp/asf
15:18:00 T:140312814794624 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: nsv
15:18:00 T:140312814794624 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: radio
15:18:00 T:140312814794624 DEBUG: CPlayerCoreFactory::GetPlayers: matched 0 rules with players
15:18:01 T:140312814794624 DEBUG: CPlayerCoreFactory::GetPlayers: adding audiodefaultplayer (3)
15:18:01 T:140312814794624 DEBUG: CPlayerCoreFactory::GetPlayers: for video=0, audio=1
15:18:01 T:140312814794624 DEBUG: CPlayerCoreFactory::GetPlayers: adding player: PAPlayer (3)
15:18:01 T:140312814794624 DEBUG: CPlayerCoreFactory::GetPlayers: for video=1, audio=1
15:18:01 T:140312814794624 DEBUG: CPlayerCoreFactory::GetPlayers: adding player: DVDPlayer (1)
15:18:01 T:140312814794624 DEBUG: CPlayerCoreFactory::GetPlayers: added 2 players
15:18:01 T:140312814794624 DEBUG: SECTION:LoadDLL(special://xbmcbin/system/players/dvdplayer/avutil-51-x86_64-linux.so)
15:18:01 T:140312814794624 DEBUG: Loading: /usr/lib/xbmc/system/players/dvdplayer/avutil-51-x86_64-linux.so
15:18:01 T:140312814794624 DEBUG: FactoryCodec - Audio: passthrough - Opening
15:18:01 T:140312814794624 DEBUG: FactoryCodec - Audio: passthrough - Failed
15:18:01 T:140312814794624 DEBUG: FactoryCodec - Audio: pcm - Opening
15:18:01 T:140312814794624 DEBUG: FactoryCodec - Audio: pcm - Opened
15:18:10 T:140312676226816 DEBUG: Suspended the Sink
15:18:29 T:140312734947072 DEBUG: Thread Jobworker 140312734947072 terminating (autodelete)
15:18:29 T:140311976191744 DEBUG: Thread Jobworker 140311976191744 terminating (autodelete)
15:18:59 T:140312718161664 DEBUG: ### [Qlock] - Delaying 240 secs
15:20:24 T:140312743339776 DEBUG: JSONRPC: Incoming request: {"jsonrpc": "2.0", "id": 1, "method": "VideoLibrary.GetMovies", "params": {"properties": ["title", "playcount", "year", "genre", "studio", "country", "tagline", "plot", "runtime", "file", "plotoutline", "lastplayed", "trailer", "rating", "resume", "art", "streamdetails", "mpaa", "director"], "limits": {"end": 20}, "sort": {"method": "random" }, "filter": {"field": "playcount", "operator": "lessthan", "value": "1"}}}
15:20:24 T:140312743339776 DEBUG: JSONRPC: Calling videolibrary.getmovies
15:20:24 T:140312743339776 DEBUG: RunQuery took 9 ms for 379 items query: select * from movieview WHERE ((movieview.playCount IS NULL OR movieview.playCount < 1))
15:20:24 T:140312743339776 DEBUG: JSONRPC: Incoming request: {"jsonrpc": "2.0", "id": 1, "method": "VideoLibrary.GetEpisodes", "params": { "properties": ["title", "playcount", "season", "episode", "showtitle", "plot", "file", "rating", "resume", "tvshowid", "art", "streamdetails", "firstaired", "runtime"], "limits": {"end": 20}, "sort": {"method": "random" }, "filter": {"field": "playcount", "operator": "lessthan", "value": "1"}}}
15:20:24 T:140312743339776 DEBUG: JSONRPC: Calling videolibrary.getepisodes
15:20:24 T:140312743339776 DEBUG: RunQuery took 11 ms for 649 items query: select * from episodeview WHERE ((episodeview.playCount IS NULL OR episodeview.playCount < 1))
15:20:24 T:140312743339776 DEBUG: JSONRPC: Incoming request: {"jsonrpc": "2.0", "id": 1, "method": "VideoLibrary.GetMusicVideos", "params": {"properties": ["title", "artist", "playcount", "year", "plot", "genre", "runtime", "fanart", "thumbnail", "file", "streamdetails"], "limits": {"end": 20}, "sort": {"method": "random"}}}
15:20:24 T:140312743339776 DEBUG: JSONRPC: Calling videolibrary.getmusicvideos
15:20:24 T:140312743339776 DEBUG: RunQuery took 0 ms for 0 items query: select * from musicvideoview
15:20:24 T:140312743339776 DEBUG: JSONRPC: Incoming request: {"jsonrpc": "2.0", "id": 1, "method": "AudioLibrary.GetAlbums", "params": {"properties": ["title", "description", "albumlabel", "artist", "genre", "year", "thumbnail", "fanart", "rating", "playcount"], "limits": {"end": 20}, "sort": {"method": "random"}}}
15:20:24 T:140312743339776 DEBUG: JSONRPC: Calling audiolibrary.getalbums
15:20:24 T:140312743339776 DEBUG: GetAlbumsByWhere query: SELECT albumview.* FROM albumview WHERE albumview.strAlbum <> ''
15:20:24 T:140312743339776 DEBUG: GetAlbumsByWhere - query took 0 ms
15:20:24 T:140312743339776 DEBUG: JSONRPC: Incoming request: {"jsonrpc": "2.0", "method": "AudioLibrary.GetArtists", "params": {"properties": ["genre", "description", "fanart", "thumbnail"], "sort": {"method": "random"}, "limits": {"end": 20}}, "id": 1}
15:20:24 T:140312743339776 DEBUG: JSONRPC: Calling audiolibrary.getartists
15:20:24 T:140312743339776 DEBUG: GetArtistsByWhere query: SELECT artistview.* FROM artistview WHERE (artistview.idArtist IN (SELECT song_artist.idArtist FROM song_artist) OR artistview.idArtist IN (SELECT album_artist.idArtist FROM album_artist)) and artistview.strArtist != '' and artistview.idArtist <> 322
15:20:24 T:140312743339776 DEBUG: Time to retrieve artists from dataset = 1
15:20:24 T:140312743339776 DEBUG: JSONRPC: Incoming request: {"jsonrpc": "2.0", "id": 1, "method": "AudioLibrary.GetSongs", "params": {"properties": ["title", "playcount", "artist", "album", "year", "file", "thumbnail", "fanart", "rating"], "filter": {"field": "playcount", "operator": "lessthan", "value": "1"}, "limits": {"end": 20}, "sort": {"method": "random"}}}
15:20:24 T:140312743339776 DEBUG: JSONRPC: Calling audiolibrary.getsongs
15:20:24 T:140312743339776 DEBUG: GetSongsByWhere query = SELECT songview.* FROM songview WHERE ((CAST(songview.iTimesPlayed as DECIMAL(5,1)) < 1))
15:20:24 T:140312743339776 DEBUG: JSONRPC: Incoming request: {"jsonrpc": "2.0", "method": "Addons.GetAddons", "params": {"properties": ["name", "author", "summary", "version", "fanart", "thumbnail"]}, "id": 1}
15:20:24 T:140312743339776 DEBUG: JSONRPC: Calling addons.getaddons
15:20:24 T:140311976191744 NOTICE: Thread Jobworker start, auto delete: true
15:20:24 T:140312743339776 DEBUG: Skin Widgets: Total time needed to request random queries: 0:00:00.144355
15:20:55 T:140311976191744 DEBUG: Thread Jobworker 140311976191744 terminating (autodelete)
Any ideas?
Thank
Stefan
@deuce and @erwin63
you guys are obviously not talking about the same problem.
+1 for me as xbmc freezes and requires reboot upon attempting to enable airplay in settings -> services -> airplay
zeroconf is enabled.
upon reboot, airplay is not enabled.
i have an acer revo r1600
and i'm running OpenELEC 3.0.0 (xbmc 12.1)
Did anyone find a resolution on this - I am having the same problem?
Obviously no solution yet..., at least no one is looking into it at the moment....
Check the thread I created, my issue was another Ubuntu box with pulse audio running the " make airplay devices available locally" once I disabled that on said box, AirPlay p. the xbmc box started working
(2013-03-30, 19:25)Oo.et.oO Wrote: [ -> ]@deuce and @erwin63
I had basically the same thing happen on my Windows 8 HTPC. Only tried it once just to see if the girlfriends iPad would work off my XBMC install. I was never motivated enough to try more. I never saw a link to a full debug log which for those of you that want this problem resolved, need to provide per the earlier request. Which is also the reason no one is working towards a solution, they don't have enough info to troubleshoot it. Again, it's not something I really needed, just a cool feature I thought I would try.
