Full Version: Media flag problem
I'm getting those flags nicely when I'm looking at individual episodes but I'm not getting anything when browsing series. This happens in every view. Another thing I noticed is that every series is in TV case (not in dvd or blu-ray as they should be) but that's probably because of my file naming, or is it?
Both things are working fine on Movies. Now that I think of this I should have tested this on some other skin as well. I will do that now and see if it's doing the same thing with other skins.
Edit: Same thing happens with Confluence. Well.. since I already posted here, any ideas?
dvd/blu-ray cases are used in the movie library only.
in the tc show library, T! uses the tv case.
so what you're seeing is correct.
media flags (if i understand you question correctly) can only be shown for video files,
whether it be a movie file or episode file.
there's no such thing as displaying meta data for a tv show.
Oh yeah. I guess I just assumed that it will show flags on series where every episode have same flags(like they usually do). I'm not sure where I got that assumption though. Thanks for your help.
Could it be somehow possible to use dvd/blu-ray cases in the tv show library?
(2013-02-02, 17:03)TujAuS Wrote: [ -> ]Could it be somehow possible to use dvd/blu-ray cases in the tv show library?
nope.
