2013-02-02, 21:37
A couple of doubts, let's see if someone can clarify.
I have a source defined as Movies, with n paths:
nfs://server/dir1
nfs://server/dir2
nfs://server/dirN
can this cause any slowdown to xbmc, compared to a single path? And when I say n folders, I probably mean 25
Also, if at some point in time I change the source paths to
nfs://anotherserver/dir1
nfs://anotherserver/dir2
nfs://anotherserver/dirN
will this cause troubles to xbmc in finding/updating/cleaning the database? Does it use the whole path or only the file name to identify movies? I suppose in the first case it is anyway possible to easily update the db, since it is for sure 3NF.
Last thing.. I noticed that accents are not correctly sorted, so <È>, italian uppercase for <è>, which is the verb <is>, is put after letter <Z>, while it should be sorted as <E> or <E'>. Any tag in advancedsettings to override this behavior?
nfs://server/dir1
nfs://server/dir2
nfs://server/dirN
