What is the best way to update Edon to Frodo on an xbmc with stable releases
I'm guessing it's through the SSH, but don't know the procedure.
If you are referring to XBMCbuntu, you don't need to use SSH. You can simply switch over to the XBMCbuntu desktop, launch a terminal window and enter the necessary commands to upgrade XBMC to Frodo.
See this wiki article, in particular section 3.2, on how to upgrade XBMC on an XBMCbuntu system:
http://wiki.xbmc.org/index.php?title=XBM..._XBMC_Live
Oh yes, thank you
I executed these lines and it worked great
sudo apt-get update
sudo apt-get install xbmc xbmc.bin
