Full Version: Flooded xbmc.log - ERROR: CAESinkALSA::HandleError(snd_pcm_writei(2)) - snd_pcm_write
Hello,
So, I played areound a bit yesterday, and switched my ION1 HTPC with my ION2 Server,
so now i have a ION2 HTPC.
And with the exception of a no sound issue efter the second reboot, wich was due to the ubuntu SSD issues, that the desktop is started before the system is actually done,
everything seemed fine.
So i vent to bed, and now today, i was going to continue configuring everything to my hearts content.
But i noticed an issue.
-rw-rw-r-- 1 marix marix 50150387831 Feb 3 09:46 xbmc.log
for thoose needing a calculating hand:
47G xbmc.log
the log starts at:
21:10:33 T:3007768384 NOTICE: Starting XBMC (12.0 Git:fb595f2), Platform: Linux (Ubuntu Raring Ringtail (development branch), 3.8.0-4-generic i686). Built on Jan 28 2013
And ends at:
09:48:16 T:2940132160 ERROR: CAESinkALSA::HandleError(snd_pcm_writei(1)) - snd_pcm_writei returned -11 (Resource temporarily unavailable)
so in 13½ hours, it has generated this logfile, and 99.9% of it contains this:
09:48:16 T:2940132160 ERROR: CAESinkALSA::HandleError(snd_pcm_writei(2)) - snd_pcm_writei returned -11 (Resource temporarily unavailable)
so, I deleted the log, im not putting 47Gb on pastebin, and rebooted.
And it seems to not happen currently, but I am still testing way, it might be because the receiver was shut down, and xbmc didnt like that?
here are some other info:
Installed using:
xbmcbuntu-12.00.Intel-NVIDIA.iso
$ uname -a
Linux carbon 3.8.0-4-generic #8-Ubuntu SMP Fri Feb 1 18:06:29 UTC 2013 i686 i686 i686 GNU/Linux
yes, the system has after install been updated to Raring.
$ cat xbmc.log
http://pastebin.com/Mmr0CKWW
Will update with more info if I am able to reproduce this flooding of the log.
Any updates on this? I have the same issue. Do you have an .asoundrc file? What audio sink is chosen in your audio preferences? Good luck.
@SorryGoFish you have posted in two similar threads, but I haven't seen your answers to your own question, nor your hardware specs of logs.
getting this same error. Here's my thread; http://forum.xbmc.org/showthread.php?tid=156018 I'm still trying things out, and ill let you know if i figure something out. What have you tried?
Hello to the XBMC community,
first of all, thank you very much for this powerful open-source Solution for mediacenters ! XBMC changed my life :-)
However, since I have upgraded my system to Frodo, I'm encountering some issues with the new XBMC Audio Engine & ALSA. It seems to be the same problem than marix but on a different hardware.
I am running an AMD E-450 APU and Ubuntu/Linux 12.04. (FYI, I'm directly running XBMC from lightdm and I have removed everything concerning PulseAudio. Nothing should interfere with my sound card)
I've have recently upgraded to Frodo. My sound is now lagging with short-cuts when I'm playing audio files. Moreover, my XBMC log is filled with many many lines like those when I'm playing a music or a video file :
15:34:00 T:2969209664 ERROR: CAESinkALSA::HandleError(snd_pcm_writei(1)) - snd_pcm_writei returned -11 (Resource temporarily unavailable)
15:34:00 T:2969209664 ERROR: CAESinkALSA::HandleError(snd_pcm_writei(2)) - snd_pcm_writei returned -11 (Resource temporarily unavailable)
I have investigated the problem: it only appears when I set the XBMC audio output device to "HD Audio Generic (both) HDMI0" or "Default (HD Audio Generic HDMI0)".
Setting the same option to "HDA ATI SB ALC887-VA Analog" or "HD-Audio Generic HDMI" solves the problem but the audio is not output through HDMI and Analog at the same time.
On Eden, everything worked perfectly. I can confirm that the bug appears on the following versions of Frodo:
- Frodo RC2 and RC3.
- Frodo from Git "master" branch (commit b50636f30ad0ef9b6894d9429de5d2b8f5678f6b from 2013-02-24)
- Frodo from Git "Frodo" branch (commit fa23eb624ce7d832167f17efcb2338da516aa8f5 from 2013-02-17)
Here are some useful information about my system (hope I didn't forget anything. Tell me otherwise).
* The output of uname command: Linux mediacenter 3.2.0-38-generic-pae #61-Ubuntu SMP Tue Feb 19 12:39:51 UTC 2013 i686 athlon i386 GNU/Linux
* xbmc.log: http://pastebin.com/r8PNjUVy
* Architecture : i686
* XBMC installed from Github
* Ubuntu/Linux 12.04
* CPU/GPU: AMD E-450 APU
* ATI Catalyst (12.10) drivers manually installed.
I should appreciate your help on the problem.
Best regards
Snoapx
Hehe - you made quite a mess with custom asound.conf and your semi removal of pulseaudio
sudo apt-get remove --purge pulseaudio libasound2-plugins libasound2-plugins:i386
sudo mv /etc/asound.conf /etc/schwachsinn.conf
mv ~/.asound ~/not-better.conf
sudo reboot
And to add for your amd - you should use an xvba enabled build.
sudo apt-add-repository ppa:wsnipex/xbmc-xvba-frodo
sudo apt-get update
sudo apt-get install xbmc-bin xbmc
Under video playback, select XVBA afterwards, disable VAAPI, disable VDPAU. In the Audio Settings disable LPCM, disable TrueHD, disable DTS-HD and thank AMD that they don't support this on linux.
I had the same problem an it was solved by switching System>Settings>Sound output>Sound device/Passthtough to: HDA Nvidia , ONK TC-NR609 on HDMI (You probably have another name depending on Receiver)
