2013-02-03, 11:40
Hi, Pls could someone assist? I am very new to Linux, and having some problems getting XBMCbuntu to work with slideshow.
I am serving up photos from my Windows 8 pictures library using WMP inbuilt upnp server. I can see XBMC in devices, and enabled Windows privileges for the device.
On XBMC, I can see the Windows 8 PC in the Auto Discover upnp devices, and I can browse all the PC folders, see and generate thumbnails. When I select 'Start Slideshow here' on XBMC, I get a blank black screen only. I've checked in the PC folder to ensure I have only valid .jpg files. I've also tried the same as above using a W7 PC - same problem.
I've attached a log file.
18:42:17 T:3038566144 NOTICE: -----------------------------------------------------------------------
18:42:17 T:3038566144 NOTICE: Starting XBMC (12.0 Git:fb595f2), Platform: Linux (Ubuntu 12.10 - XBMCbuntu, 3.5.0-22-generic i686). Built on Jan 28 2013
18:42:17 T:3038566144 NOTICE: special://xbmc/ is mapped to: /usr/share/xbmc
18:42:17 T:3038566144 NOTICE: special://xbmcbin/ is mapped to: /usr/lib/xbmc
18:42:17 T:3038566144 NOTICE: special://masterprofile/ is mapped to: /home/dave/.xbmc/userdata
18:42:17 T:3038566144 NOTICE: special://home/ is mapped to: /home/dave/.xbmc
18:42:17 T:3038566144 NOTICE: special://temp/ is mapped to: /home/dave/.xbmc/temp
18:42:17 T:3038566144 NOTICE: The executable running is: /usr/lib/xbmc/xbmc.bin
18:42:17 T:3038566144 NOTICE: Local hostname: inca
18:42:17 T:3038566144 NOTICE: Log File is located: /home/dave/.xbmc/temp/xbmc.log
18:42:17 T:3038566144 ERROR: CAESinkOSS::EnumerateDevicesEx - Failed to open mixer: /dev/mixer
18:42:17 T:3038566144 NOTICE: Enumerated ALSA devices:
18:42:17 T:3038566144 NOTICE: Device 1
18:42:17 T:3038566144 NOTICE: m_deviceName : @
18:42:17 T:3038566144 NOTICE: m_displayName : Default (HDA Intel ALC662 rev1 Analog)
18:42:17 T:3038566144 NOTICE: m_displayNameExtra:
18:42:17 T:3038566144 NOTICE: m_deviceType : AE_DEVTYPE_PCM
18:42:17 T:3038566144 NOTICE: m_channels : FL,FR,BL,BR,FC,LFE
18:42:17 T:3038566144 NOTICE: m_sampleRates : 44100,48000,96000
18:42:17 T:3038566144 NOTICE: m_dataFormats : AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE
18:42:17 T:3038566144 NOTICE: Device 2
18:42:17 T:3038566144 NOTICE: m_deviceName : @:CARD=Intel,DEV=0
18:42:17 T:3038566144 NOTICE: m_displayName : HDA Intel
18:42:17 T:3038566144 NOTICE: m_displayNameExtra: ALC662 rev1 Analog
18:42:17 T:3038566144 NOTICE: load settings...
18:42:17 T:3038566144 NOTICE: special://profile/ is mapped to: special://masterprofile/
18:42:17 T:3038566144 NOTICE: loading special://masterprofile/guisettings.xml
18:42:17 T:3038566144 NOTICE: Getting hardware information now...
18:42:17 T:3038566144 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
18:42:17 T:3038566144 NOTICE: Loaded playercorefactory configuration
18:42:17 T:3038566144 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
18:42:17 T:3038566144 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
18:42:17 T:3038566144 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
18:42:17 T:3038566144 NOTICE: Loaded settings file from special://profile/advancedsettings.xml
18:42:17 T:3038566144 NOTICE: Contents of special://profile/advancedsettings.xml are...
20:53:08 T:3038566144 DEBUG: Loading the current image upnp://74561853-6d48-4f9b-8777-c6a84754eea9/B-7534
20:53:08 T:2782837568 DEBUG: CUPnPDirectory::GetResource - resource protocol info 'http-get:*:image/jpegLNA.ORG_PN=JPEG_LRG;DLNA.ORG_OP=01;DLNA.ORG_FLAGS=00f00000000000000000000000000000'
20:53:08 T:2782837568 DEBUG: File::Stat - redirecting implementation for upnp://74561853-6d48-4f9b-8777-c6a84754eea9/B-7534
20:53:08 T:2782837568 INFO: msg: PICTURE::LoadImage: Unable to open image: upnp://74561853-6d48-4f9b-8777-c6a84754eea9/B-7534 Error: (115)
20:53:08 T:2782837568 ERROR: Texture manager unable to load file: upnp://74561853-6d48-4f9b-8777-c6a84754eea9/B-7534
20:53:08 T:3038566144 DEBUG: We have an error loading a picture!
20:53:08 T:3038566144 ERROR: Error loading the current image upnp://74561853-6d48-4f9b-8777-c6a84754eea9/B-7534
20:53:08 T:3038566144 DEBUG: Loading the current image upnp://74561853-6d48-4f9b-8777-c6a84754eea9/B-7457
20:53:08 T:2782837568 DEBUG: File::Stat - redirecting implementation for upnp://74561853-6d48-4f9b-8777-c6a84754eea9/B-7457
20:53:08 T:2782837568 INFO: msg: PICTURE::LoadImage: Unable to open image: upnp://74561853-6d48-4f9b-8777-c6a84754eea9/B-7457 Error: (115)
20:53:08 T:2782837568 ERROR: Texture manager unable to load file: upnp://74561853-6d48-4f9b-8777-c6a84754eea9/B-7457
20:53:08 T:3038566144 ERROR: Error loading the current image upnp://74561853-6d48-4f9b-8777-c6a84754eea9/B-7457
20:53:08 T:3038566144 DEBUG: Loading the current image upnp://74561853-6d48-4f9b-8777-c6a84754eea9/B-7582
20:53:08 T:2782837568 DEBUG: File::Stat - redirecting implementation for upnp://74561853-6d48-4f9b-8777-c6a84754eea9/B-7582
20:53:08 T:2782837568 INFO: msg: PICTURE::LoadImage: Unable to open image: upnp://74561853-6d48-4f9b-8777-c6a84754eea9/B-7582 Error: (115)
20:53:08 T:2782837568 ERROR: Texture manager unable to load file: upnp://74561853-6d48-4f9b-8777-c6a84754eea9/B-7582
20:53:08 T:3038566144 ERROR: Error loading the current image upnp://74561853-6d48-4f9b-8777-c6a84754eea9/B-7582
